edinlexusV8 Posted April 11, 2010 Share Posted April 11, 2010 Folks, Scott - on the other forum has done this DIY mod to his callipers and rotor. I would like to know if anybody in here have done this before and what are the results like. Does this mod handle the stress under braking as the stock setup. I would like to know your opinions on this. http://www.clublexus.com/forums/suspension-and-brakes/492868-got-an-aftermarket-big-brake-kit-and-your-wheels-won-t-fit-dyi.html PS: Scott is an engineer himself and has done great projects like this in the past. He is very good at these. But I am not sure cutting a piece and welding it back would be good enough as the uncut one. Also not sure about the allen bolts on the rotor whether they can handle more stress due to the added spacer under heavy braking Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 11, 2010 Share Posted April 11, 2010 As far as im concerned its a scary bodge that should fail an mot and not be on the rd. Quote Link to comment Share on other sites More sharing options...
DaveR Posted April 11, 2010 Share Posted April 11, 2010 Mmm... Sounds a bit dodgy to me, but then I don't claim to be an expert. I'd personally prefer the warm fuzzy feeling of knowing my brakes and everything to do with them are made from one piece, you know? BTW, please no one get anal about that statement - I know there are lots of bits, but you know what I mean! Quote Link to comment Share on other sites More sharing options...
johnd-mkiv Posted April 11, 2010 Share Posted April 11, 2010 not a fan of welding them lugs on thats a bit naughty Quote Link to comment Share on other sites More sharing options...
Rob Posted April 11, 2010 Share Posted April 11, 2010 Despite knowing very little about metallurgy and welding and casting, every fibre of my body screams out "Noooooooooo" when I read that thread. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 11, 2010 Share Posted April 11, 2010 That looks like light ally for the spacer? On a steel disc? Just buy the kit thats designed for the car. Gash Quote Link to comment Share on other sites More sharing options...
nevins Posted April 11, 2010 Share Posted April 11, 2010 Be good to see what happens under heavy braking. I say we start a pool on to what happens to the car. The odds have to be against him lol. Quote Link to comment Share on other sites More sharing options...
edge Posted April 11, 2010 Share Posted April 11, 2010 I would of done it properly and used wood screws and super glue. Quote Link to comment Share on other sites More sharing options...
nevins Posted April 11, 2010 Share Posted April 11, 2010 I would of done it properly and used wood screws and super glue. Or the blue peter method, double sided sticky tape and pipe cleaners Quote Link to comment Share on other sites More sharing options...
edinlexusV8 Posted April 11, 2010 Author Share Posted April 11, 2010 Scott is a pretty smart engineer but I cannot believe he did something like this. He has done some great projects in the past but this is the worst of all I suppose. I do have a problem too with my big brake kit when I upgraded my brakes. I just picked a set of alloys that would fit over them to sort the issue. Quote Link to comment Share on other sites More sharing options...
nevins Posted April 11, 2010 Share Posted April 11, 2010 Scott is a pretty smart engineer but I cannot believe he did something like this. He has done some great projects in the past but this is the worst of all I suppose. I do have a problem too with my big brake kit when I upgraded my brakes. I just picked a set of alloys that would fit over them to sort the issue. The safer and wiser method. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted April 11, 2010 Share Posted April 11, 2010 not a chance that is safe! Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 11, 2010 Share Posted April 11, 2010 i would have baught; A. bigger wheels B. brakes that fir under my wheels simples . squeek Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 12, 2010 Share Posted April 12, 2010 Spacer is fine, but the lug change is only as good as the prep and welding, which in his case looks a bit Heath Robinson. I'd want to X-Ray the welds after completion, and do it with the upright stripped and blasted, off the car. A hell of a lot of trouble to nail cheap and nasty calipers and discs on, IMHO when UK calipers are available easily and for little money. Quote Link to comment Share on other sites More sharing options...
DaveR Posted April 12, 2010 Share Posted April 12, 2010 As well as being dodgy, it really just seems like making more work than is necessary. Re-designing and then re-making an entire braking system? Or bolting on new wheels? Mmm... Quote Link to comment Share on other sites More sharing options...
captainchaos Posted April 12, 2010 Share Posted April 12, 2010 who would like to play catch the caliper? welding material without using the correct weld procedure etc etc etc BIG NO NO Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 12, 2010 Share Posted April 12, 2010 In fairness to him the uprights are forged steel. Quote Link to comment Share on other sites More sharing options...
captainchaos Posted April 12, 2010 Share Posted April 12, 2010 still but both require weld procedures even the simple things like pre heating is highly recommended and from them pictures I cant see any evidence of that. Quote Link to comment Share on other sites More sharing options...
Soop Dogg Posted April 12, 2010 Share Posted April 12, 2010 Sorry to go a little off topic, but it annoys me when I see this on American forums: Add paint and wala! New ears to recess the caliper. Wala??? Where did you get that, you muppet! It's voila, FFS!! (and breathe....) Oh - that welding idea on his brakes just looks to me like it will end in tears. And blood. And bits of bone and snot and maybe a few teeth mixed in for good measure. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 12, 2010 Share Posted April 12, 2010 Sorry to go a little off topic, but it annoys me when I see this on American forums: Wala??? Where did you get that, you muppet! It's voila, FFS!! (and breathe....) Oh - that welding idea on his brakes just looks to me like it will end in tears. And blood. And bits of bone and snot and maybe a few teeth mixed in for good measure. i share your opinion on the "wala" Quote Link to comment Share on other sites More sharing options...
Rob Posted April 12, 2010 Share Posted April 12, 2010 at the end of the day I guess I am the one that has to live with it. That annoyed me. Unless where he lives, they only allow one car on any bit of road at any one time Quote Link to comment Share on other sites More sharing options...
