Chris Wilson Posted April 12, 2010 Share Posted April 12, 2010 Sort the blown off hose, fully charge the battery, fit new correct plugs and it should start. Miss any of the above and you'll still probably be posting here when hell freezes over Quote Link to comment Share on other sites More sharing options...
magnos Posted April 12, 2010 Author Share Posted April 12, 2010 (edited) will do it 2morrow after work ,Mark @ phoenix fitted iridium spark plugs and i used them for 8000 miles so far,`ill take them out and i`ll check with Halfords for new ones,thanks again Edited April 12, 2010 by magnos (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 12, 2010 Share Posted April 12, 2010 The plugs are not exactly trivial to get to, just so you don't think it's a five minute job. Quote Link to comment Share on other sites More sharing options...
magnos Posted April 12, 2010 Author Share Posted April 12, 2010 i can imagine but i need to do it, i can`t get it out of my head :)i need to know what`s wrong .. Quote Link to comment Share on other sites More sharing options...
Branners Posted April 13, 2010 Share Posted April 13, 2010 I see you say the car was left standing for 3 months, but that the battery runs out after a week. Have you had to jump start the car recently? The UK spec alarm does not like being jump started and fries itself quite easily. That could stop the fuel pump and ignition system working possibly. You may need to disconnect the battery from the alarm for long enough for it to run down its own internal batteries and reset, or get somebody to take a look at the car as I think it may be more than just a spark problem. Quote Link to comment Share on other sites More sharing options...
magnos Posted April 13, 2010 Author Share Posted April 13, 2010 i've disconnected the battery before it has been left off road, i did jumped started a few times in the past till someone told me to disconnect the battery when i'm not driving it every day and it worked fine that day till that pipe came out from the joint , i left it over the night and in the morning i've start the engine for a few minutes while i was checking the car and when i've been told later that they to check the intercooler pipes it stalled Quote Link to comment Share on other sites More sharing options...
magnos Posted April 13, 2010 Author Share Posted April 13, 2010 I`ve cleaned the spurk plugs with brake and clutch cleaner and l left them over the night to dry out, wanted to change them for new ones but Halfords don`t do them ,they were in very bad shape IMO ,wet ,dirty with black liquid all covered,hope this was the problem Quote Link to comment Share on other sites More sharing options...
BazzaAlpine Posted April 13, 2010 Share Posted April 13, 2010 Black liquid? Correct me if I'm wrong but wouldn't that imply oil leak in the chambers? or just the result og the junk being sucked in because the pipe was off? Hope it's all okay when you get some new plugs in there. Quote Link to comment Share on other sites More sharing options...
jon5698 Posted April 13, 2010 Share Posted April 13, 2010 When i changed my spark plugs i noticed oil on the threads and started to think the worse, until i noticed that the rocker cover bolts were all loose! i got 2 new gasketts from Mr T and tightened them all up and it has been ok since. Quote Link to comment Share on other sites More sharing options...
Homer Posted April 13, 2010 Share Posted April 13, 2010 I`ve cleaned the spurk plugs with brake and clutch cleaner and l left them over the night to dry out, wanted to change them for new ones but Halfords don`t do them ,they were in very bad shape IMO ,wet ,dirty with black liquid all covered,hope this was the problem Black fluid will just be soot/fuel buld up. New plugs would be ideal at this point. This is very common so don't stress, happens to many of us New plugs, full battery, it'll start fine. Quote Link to comment Share on other sites More sharing options...
magnos Posted April 14, 2010 Author Share Posted April 14, 2010 Once again I would like to thanks everyone for their support ,the car is running perfect and its all down to the members of this club :) cheers Quote Link to comment Share on other sites More sharing options...
Homer Posted April 14, 2010 Share Posted April 14, 2010 Good stuff, glad you got it sorted. Was it soiled plugs then? Quote Link to comment Share on other sites More sharing options...
danger_supe Posted April 14, 2010 Share Posted April 14, 2010 phew! i tell you ive been hooked on this thread wondering how you were getting on glad to hear its ok now! that would put the shits up me for sure! Quote Link to comment Share on other sites More sharing options...
magnos Posted April 14, 2010 Author Share Posted April 14, 2010 yes it was Quote Link to comment Share on other sites More sharing options...
edge Posted April 14, 2010 Share Posted April 14, 2010 Goto http://www.sparkplugs.co.uk and order some plugs and they are quite cheap also. Glad you got it sorted though Quote Link to comment Share on other sites More sharing options...
magnos Posted April 14, 2010 Author Share Posted April 14, 2010 Mark @Phoenix fitted iridiums shell i buy the same? , my car is not full bpu yet Quote Link to comment Share on other sites More sharing options...
Homer Posted April 14, 2010 Share Posted April 14, 2010 Your choice really. I personally don't see the point in them at stock, BPU or even small/medium single power levels but some here swear by them. Set of NGK coppers are about £14 and last around 5k miles, set of iridiums are £40-60 and last around 8k miles. Have a read here for the specs required: http://www.mkivsupra.net/vbb/showthread.php?t=41927 Quote Link to comment Share on other sites More sharing options...
magnos Posted April 14, 2010 Author Share Posted April 14, 2010 ""Denso and NGK recommend their Iridium’s only be replaced every 30,000miles (in some applications iridium plugs will last 120,000miles BUT NOT A SPORTSCAR!), and this is 5 times the life a copper plug."" iridiums sounds good,thanks Quote Link to comment Share on other sites More sharing options...
Homer Posted April 14, 2010 Share Posted April 14, 2010 They're good for 8k miles mate, little more. Don't beleive the bullshit from the resellers or OEM's, it goes out of the window as soon as you start making changes to the stock system. It's, well, bullshit. The best mileage I ever got from a set of top priced Denso IK's was 9k, but they were dying well before then. Quote Link to comment Share on other sites More sharing options...
Ian C Posted April 14, 2010 Share Posted April 14, 2010 They're good for 8k miles mate, little more. Don't beleive the bull$#@! from the resellers or OEM's, it goes out of the window as soon as you start making changes to the stock system. It's, well, bull$#@!. The best mileage I ever got from a set of top priced Denso IK's was 9k, but they were dying well before then. I can't remember the last time I changed my plugs Still on the same ones I put in when I went single about 4 years ago, prob 20,000 miles + They certainly aren't coppers, not sure exactly what they are it's been so long! Quote Link to comment Share on other sites More sharing options...
magnos Posted April 15, 2010 Author Share Posted April 15, 2010 i'll leave them on for a while , it starts fine , idle it's fine ,they are ok,i'll have them changed when the next service is due though Quote Link to comment Share on other sites More sharing options...
secondjump Posted April 15, 2010 Share Posted April 15, 2010 I can't remember the last time I changed my plugs Still on the same ones I put in when I went single about 4 years ago, prob 20,000 miles + They certainly aren't coppers, not sure exactly what they are it's been so long! Same here...IK24's on a single and over 16k:) Quote Link to comment Share on other sites More sharing options...
