dr_jekyll Posted April 11, 2010 Share Posted April 11, 2010 after fitting my new gearbox my speedo has gone crazy? if im in 3rd gear and i floor it it flyes upto 180mph and then boinces around abit, if im driving sensibly it stays pretty normal . i know its probably a faulty speed sensor or speedo converter , but my only question is, when the speedo sees 180 will this trigger the limiter . so if i was in 4th with my foot down and the speedo hits 180 will the limiter kick in ? or its ther a seperate programme in the ecu that regulates that regardless of the speedo? Quote Link to comment Share on other sites More sharing options...
Stratty Posted April 11, 2010 Share Posted April 11, 2010 Very interesting as mine does exactly the same thing since having a new motor fitted. I was told to check to ensure the bolts on the speedo were done up correctly or as you have mentioned, the converter needs replacing. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 11, 2010 Author Share Posted April 11, 2010 Very interesting as mine does exactly the same thing since having a new motor fitted. I was told to check to ensure the bolts on the speedo were done up correctly or as you have mentioned, the converter needs replacing. dose yours hit the speed limiter, mines not driving properly on full throttle now seems to hesitate a bit and my afrs are all showing rich , might not be conjoined with the mad speedo butr seems straige how it happend together, i will unbolt the old speed sensor from my old box and swap them and see if that helps first i think Quote Link to comment Share on other sites More sharing options...
Stratty Posted April 11, 2010 Share Posted April 11, 2010 No, it doesnt hit the limiter. But then again, it is meant to be a delimiter as well.. Part of it sounds like the same problem I have tho. Quote Link to comment Share on other sites More sharing options...
