JS2004 Posted April 9, 2010 Share Posted April 9, 2010 Just a quick question regards to the rear area of the car, around the petrol flap. (not sure if this is called the rear wing?) If I were to take the wheel off, can I get behind that panel to knock a dent out from the inside? Ive had a feel / look around the rear wheel arch and it looks like its sealed up, but I dont know if that part can be taken off. Basically im trying to figure out if I can remove the crease thats been on my car since I bought it. It was caused the night before I was due to buy it, and the seller was supposed to fix it as part of the deal - but changed his mind. I would take it to a bodyshop but im convinced the last time I went there I was overcharged a fair whack.. and im not 100% happy with the result either. I can get some pics if that would help - its been an eyesore for a long time and now the weather is better I want to sort it. Additionally if I do take it to a bodyshop I think it would help if I "knew" what I was talking about so the quote isnt astronomical again.. Cheers Quote Link to comment Share on other sites More sharing options...
Abz Posted April 9, 2010 Share Posted April 9, 2010 I'd like some information on this as well so will checking this thread. I also have a small crease at the back quarter panel of the car which I would like to take out, I do believe you would need to get off the plastic trim to access it but not sure. Quote Link to comment Share on other sites More sharing options...
JS2004 Posted April 9, 2010 Author Share Posted April 9, 2010 I think the plastic trim does need to come out, but not sure how.. I have had the boot panels out (from inside the boot) - but until I install my new struts I cant work around much inside the boot. I want to see if it will just pop out, and the it will be a case of trying to get the paint damage fixed - the paint hasnt been cracked, but there is a speckled white horizontal line at the center of the crease. I am assuming it a jack up, wheel off, plastic trim bit out and then push from inside type of affair.. but just for bodywork the garages / bodyshops round here go "ohh import.. pricy".. as if import makes much difference to the bodywork.. =/ Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted April 9, 2010 Share Posted April 9, 2010 Just pay a dent removal company to come out and have a look at it. You'll never get it right and they will only charge around 60-100 quid for a panel. Quote Link to comment Share on other sites More sharing options...
Dave17 Posted April 9, 2010 Share Posted April 9, 2010 I had a dent removal company out to do one there when i reversed in to my garage....He drilled a small hole through the plastic cover and used an array of fancy prong things to it out, cost £80. I wouldnt fancy having a go at that myself because of how curved the panel is, the chap had a strange measuring tool to make sure he got it exactly the right angle. Quote Link to comment Share on other sites More sharing options...
