wantasupra Posted April 8, 2010 Share Posted April 8, 2010 hi been over two weeks without indicators, really getting to me, so far changed relay and fuses and hazzard switch, no hazzards if i push hazzards on nothing. but with hazzard switch on i can get my drivers side indicators working. switch to pass side indicators will freak everything flashes like some sort of earth fault on dash blows fuse in dash panel. i checked wiring including ripping out the alarm system that was badly wired in, and started again. could it be anything to do with the speedo cluster thats causing faults.. if you read any post by me, i got stung really bad on car insurance and just dont have funds this month to get an auto electrition out. i know its a lot to ask maybe some one in kent my be able to help me fault find, i can pay petrol and a bit of cash. or if your local and have a spare speedo cluster i can try. any ideas please can you help me. thanks b Quote Link to comment Share on other sites More sharing options...
JustGav Posted April 8, 2010 Share Posted April 8, 2010 I can provide you with a few wiring diagrams, but that sounds like you have a little bit of tracing to do.... Quote Link to comment Share on other sites More sharing options...
wantasupra Posted April 8, 2010 Author Share Posted April 8, 2010 I can provide you with a few wiring diagrams, but that sounds like you have a little bit of tracing to do.... hi gav, i have some wiring diagrams and tryed to trace stuff but ended up getting very confused, all seems to be correct as followed. but why is the hazzard switch working backwards. thats what leads me to poss short on clocks. thanks b Quote Link to comment Share on other sites More sharing options...
nevins Posted April 8, 2010 Share Posted April 8, 2010 could be a number of things really. In the past I have had similar faults on cars and resulted in the following being faulty. hazard relay hazard switch This was not on a supra but was common on vw's. Quote Link to comment Share on other sites More sharing options...
wantasupra Posted April 8, 2010 Author Share Posted April 8, 2010 could be a number of things really. In the past I have had similar faults on cars and resulted in the following being faulty. hazard relay hazard switch This was not on a supra but was common on vw's. thats what i thought, the thing is i have replaced both off them, b Quote Link to comment Share on other sites More sharing options...
JustGav Posted April 8, 2010 Share Posted April 8, 2010 Earth problem? check all your earthing points..... Quote Link to comment Share on other sites More sharing options...
wantasupra Posted April 8, 2010 Author Share Posted April 8, 2010 Earth problem? check all your earthing points..... ok will try now.. just trying to find what earth wires are where on the dash. i guessing i could be lots. thanks guys starting to get a bit positive, Quote Link to comment Share on other sites More sharing options...
JustGav Posted April 8, 2010 Share Posted April 8, 2010 Try the two on either side just below the dash on the door sill. Colour coded black/white. Those are the two key main ones for the dash loom section. Quote Link to comment Share on other sites More sharing options...
wantasupra Posted April 8, 2010 Author Share Posted April 8, 2010 my flasher relay has blown again.run out of fuses too i try to source another one. im sure im not ment to own a supra.. any one know online shops that sell flasher relays, thanks b Quote Link to comment Share on other sites More sharing options...
Abz Posted April 8, 2010 Share Posted April 8, 2010 Trying sending Supraturbochris a PM, his got a garage in Kent which might have some spare parts or could help solve your issue? Quote Link to comment Share on other sites More sharing options...
wantasupra Posted April 8, 2010 Author Share Posted April 8, 2010 Trying sending Supraturbochris a PM, his got a garage in Kent which might have some spare parts or could help solve your issue? hi abz will pm him thank you. b Quote Link to comment Share on other sites More sharing options...
Abz Posted April 8, 2010 Share Posted April 8, 2010 hi abz will pm him thank you. b No worries, hope you get it sorted B Quote Link to comment Share on other sites More sharing options...
nevins Posted April 8, 2010 Share Posted April 8, 2010 If the fuse and relays blowing you have a short to earth somewhere. Check for trapped wires, or you will end up in the same position replacing the parts over and over. Quote Link to comment Share on other sites More sharing options...
swich Posted April 8, 2010 Share Posted April 8, 2010 I had the same sort of problem on a different car, turned out to be an earth wire in the boot. Quote Link to comment Share on other sites More sharing options...
wantasupra Posted April 9, 2010 Author Share Posted April 9, 2010 just waiting for some more fuses and relays to turn up, then i can get started again. im going to locate earth wires from pass side indicators and renew them and same for dash ones, also my speedo converter starting to play up. so this might be part of the problem.. just cant do much till i get parts, thanks for the replys b Quote Link to comment Share on other sites More sharing options...
Dave Posted April 9, 2010 Share Posted April 9, 2010 is the plug in the back of the hazzard switch in the socket correctly,pull off the dash panel and have a look, see if any of the wires are broken .i had this the plug wasnt all the way in Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted April 10, 2010 Share Posted April 10, 2010 When you used to arm the badly wired alarm, did the indicators flash? Quote Link to comment Share on other sites More sharing options...
wantasupra Posted April 15, 2010 Author Share Posted April 15, 2010 update. still not good. replaced relay and fuses. all electrics work apart from pass side indicators and hazzard switch, switch drivers side indicator on fine correct speed flashing flashing on speedo, click the switch to pass side then blows the fuse. still blowing a fuse the 7.5amp one in dash, not engine bay one that is fine now as they were both blowing, tested wiring looms {continuity tester/multi meter} they test fine. now i checked the continuity on the hazard switch its showing faulty so i need another one, this one is a replacement of a member that i brought, my oringal one was duff on all continuity tests. the one of member is just one pin out that do not test correct. allso tested indicator switch wiring that is fine too. now on to get another hazzard and maybe my fault will go, any input would be great. if you think i may have over looked something. thanks b Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted April 15, 2010 Share Posted April 15, 2010 Where abouts in kent are you mate, there are a few of us round here that may be able to quickly swap the switch out to confirm the problem. Quote Link to comment Share on other sites More sharing options...
wantasupra Posted April 15, 2010 Author Share Posted April 15, 2010 Where abouts in kent are you mate, there are a few of us round here that may be able to quickly swap the switch out to confirm the problem. maidstone town center thanks b Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted April 15, 2010 Share Posted April 15, 2010 Ahhh, I remember now, you brought your red supra to the bluewater meet once. I'm in Sidcup mate. Not sure how far you're willing to travel with no indicators Quote Link to comment Share on other sites More sharing options...
wantasupra Posted April 15, 2010 Author Share Posted April 15, 2010 Ahhh, I remember now, you brought your red supra to the bluewater meet once. I'm in Sidcup mate. Not sure how far you're willing to travel with no indicators i be fine if every turn is right if i turn left i may upset some one. pet hate of mine not using indicators. b Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted April 15, 2010 Share Posted April 15, 2010 Well, I'm in this evening if you wanted to try it out. Quote Link to comment Share on other sites More sharing options...
wantasupra Posted April 15, 2010 Author Share Posted April 15, 2010 Well, I'm in this evening if you wanted to try it out. cheers for the offer, i got one in the post so might as well wait a few more days, wont hurt.. i can get to tescos and back only using my pass indicator thanks to maidstone one way system. b Quote Link to comment Share on other sites More sharing options...
wantasupra Posted April 22, 2010 Author Share Posted April 22, 2010 update.. getting there. got hazzards working fine and left and right with out blowing, dodgy conection in engine bay fuse box.removed fuse box wiring and fixed. still problem is. my rear indicators dont light up hazzards or indicators. so trying to find the plug that comes from the rear light loom and goes too the fuse box inside car.. i think its a blue connector may be the white loom plug next to it.. anyone know which one. i cant seem to find any faults in the wiring. or can i put new earth on indicators ans run a new positive wire to the other indicator lights. any thoughts thanks b Quote Link to comment Share on other sites More sharing options...
