narbar Posted April 7, 2010 Share Posted April 7, 2010 Hi, im currently aware about the dust guard issues and that it will need to be replaced with the UK issue but I was also wondering if there were any other nigly bits I need to worry about? Im also replacing the brake lines with uprated ones and was wondering if any special tools were needed and how the best way to do it was? One last question, whats the best brake fluid for the UK brakes Thanks guys Quote Link to comment Share on other sites More sharing options...
Scott Posted April 7, 2010 Share Posted April 7, 2010 A good set of brake line spanners (can't remember the technical name) is a necessity IMO. Not a set of cheap ebay ones as they will flare out and be the wrong size etc. They look like a ring spanner only with a notch out of them. Sort of hybrid between a regular spanner and a ring spanner. Quote Link to comment Share on other sites More sharing options...
narbar Posted April 7, 2010 Author Share Posted April 7, 2010 Are they any specific sizes or is it easier for the whole set? Quote Link to comment Share on other sites More sharing options...
Abz Posted April 7, 2010 Share Posted April 7, 2010 With regards to brake fluid I would maybe recommend Motul 5.1 http://www.camskill.co.uk/products.php?plid=m1b1101s4403p57246&rs=gb Quote Link to comment Share on other sites More sharing options...
Nic Posted April 7, 2010 Share Posted April 7, 2010 http://planetsoarer.com/suprabrakesII/SupraBrakeUpgrade.htm Quote Link to comment Share on other sites More sharing options...
narbar Posted April 7, 2010 Author Share Posted April 7, 2010 thanks for the replies guys, ill have a look at that brake fluid looks like it will do the job And thanks for that guide, just need to sort the brake lines off now, ive removed them from the actual caliper but how do you remove it brake line from the caliper from the actual car? Thanks Dean Quote Link to comment Share on other sites More sharing options...
narbar Posted April 7, 2010 Author Share Posted April 7, 2010 Actually one more quick question, with regards to the anti squeal shimes, do they need to be stuck to the pistons and pads? thanks Quote Link to comment Share on other sites More sharing options...
Terminator Posted April 7, 2010 Share Posted April 7, 2010 No sticking required. Quote Link to comment Share on other sites More sharing options...
Sted Posted April 7, 2010 Share Posted April 7, 2010 Hi, im currently aware about the dust guard issues and that it will need to be replaced with the UK issue but I was also wondering if there were any other nigly bits I need to worry about? Thanks guys Have you checked that your wheels will fit over uk brakes? From personal experience I found it hard to find wheels that will clear uk brakes. Quote Link to comment Share on other sites More sharing options...
narbar Posted April 7, 2010 Author Share Posted April 7, 2010 thats the last check ive got to do, im going to check tomorrow but they should be ok, if there not theres going to be a full set of UK brakes up for sale very soon lmao Quote Link to comment Share on other sites More sharing options...
Sted Posted April 7, 2010 Share Posted April 7, 2010 Hope all goes smoothly. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 7, 2010 Share Posted April 7, 2010 Top tip mate, when you fit the calipers, make sure you put them on the right sides, bleed nipples uppermost. Otherwise youre left with a brake problem that lasts 9 months costs you hundreds of pounds, only to find the rears were 'upside down' Quote Link to comment Share on other sites More sharing options...
narbar Posted April 7, 2010 Author Share Posted April 7, 2010 thanks for the tip Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted April 7, 2010 Share Posted April 7, 2010 Having experienced big brake kits, UK's and today uprated Jspecs I would have to say for road use and occational track outages that uprated jSpecs perform exceptionally well. Decent disks, Porterfield R4 pads, Braided hoses and Motul 660 fluid I was shocked at just how well the JSpec brakes can perform. Quote Link to comment Share on other sites More sharing options...
narbar Posted April 8, 2010 Author Share Posted April 8, 2010 can you notice the difference with braided hoses? or is it just the best thing to do to compliment the new disks and brake fluid and pads? Quote Link to comment Share on other sites More sharing options...
bignum Posted April 8, 2010 Share Posted April 8, 2010 Having experienced big brake kits, UK's and today uprated Jspecs I would have to say for road use and occational track outages that uprated jSpecs perform exceptionally well. Decent disks, Porterfield R4 pads, Braided hoses and Motul 660 fluid I was shocked at just how well the JSpec brakes can perform. Quote Link to comment Share on other sites More sharing options...
Kirk Posted April 8, 2010 Share Posted April 8, 2010 And thanks to you sir ive now saved a fair bit of money! Caliper refurb kits are on order Quote Link to comment Share on other sites More sharing options...
Scott Posted April 8, 2010 Share Posted April 8, 2010 Everyones opinion of JSpecs is in the gutter. I think it has always been down to poorly maintained brakes. Everyone says the difference between them and UK specs is night and day, I would tend to agree if they are being given pain around a fast track but for day to day use I don't think most of us would be driving hard enough or fast enough to warrant anything more than good lines, good pads and good fluid.... as long as the calipers are good. How many people have changed from J-Spec to UK spec and said how good they are? If I replaced old brakes with new ones I think I would say the same regardless of spec. If they are in better condition they will always perform better. I'm guessing, in most cases, the same would be said if they did a straight replacement with new J-Specs vs old unloved ones. Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted April 9, 2010 Share Posted April 9, 2010 Scott, you are straigh on. J-specs are really all you need for road driving. They will stop the car just as good as UK spec, just with another feel to them. Now, for trackday driving, you can't really use the J-specs. I've tried to upgrade them in various manner but no success yet. I will get to try a really good high boiling point fluid next (have CW pads), if I don't get my EU specs before next Ring trip. can you notice the difference with braided hoses? or is it just the best thing to do to compliment the new disks and brake fluid and pads? Braided hoses will make a difference but not "night and day". It'll make the pedal a bit more firm and take out a bit of the "squishiness" from it. But as the hoses are relatively cheap, its a good mod. Quote Link to comment Share on other sites More sharing options...
