V6 race engine for sale
Chris Wilson
Unique Bonner 5.8 litre race V6. All ali, 4 valve heads, 302 degree cams, Lucas EFI. 610 engine dyno BHP and 450 ft lbs torque (!!). Serious engine still in production and development. Fabulous sound, serious grunt, needs a stout gearbox and diff! £50,000 new, still available to order. Comes complete with beautiful headers and 4 bid silencers, a proper dry sump set up with tank on dash 20 (!!) lines. Was run in the ADA 02 Group C car to good effect. Recent refresh, all parts available. Would suit big sports GT, wild single seater or power a steel bodied saloon. Each cylinder is over 1 litre, it's hard to describe the noise, but it sets car alarms off and annoys neighbours. Can be twin T04 turbo charged, where it gives an honest and reliable 1100 BHP. Can be marinised. Looking for 12K complete.
The BONNER V6 5.8 litre engine has been designed specifically as a high performance
compact lightweight competition engine, with particular emphasis on ruggedness and
simplicity.
The cylinder block is cast as an open chamber and then the steel liners are screwed in to make
them a structural member. The cylinder head features a dry gas-face with 8 studs per cylinder
to eliminate any chance of gasket failure. The head to block interface is sealed by Wills rings. The cam bearings and tappet carriers are cast into
the head for simplicity.
The 3-plane crankshaft is fully counterbalanced, machined from the solid with large
journals which are heavily drilled for lightness.
The forged connecting rods and forged pistons are extremely robust, yet compact and light
for their size.The steel main bearing caps are each retained by 4 studs, which are buried deep
in the crankcase.
The timing gears are located adjacent to the flywheel to minimise torsional vibrations, and
the intermediate gearwheels in the train are used to drive the water pump, distributor,
alternator, triple gang oil pump.
The entire engine is stressed, component by component, for a maximum horsepower up to
1100 and a maximum speed up to 8000 rpm.
BONNER V6 5.8 LITRE ENGINE
SPECIFICATION
TYPE Four Stroke 60 degree V6
4 Overhead Camshafts
4 Valves per Cylinder
Liquid Cooled
Gear Driven Cams &Auxiliaries
BORE 112 mm
STROKE 98 mm
DISPLACEMENT 5793 cc
NATURALLY ASPIRATED
BRAKE HORSEPOWER 610 @ 7,300 rpm
TORQUE 450 lbs ft @ 6,200 rpm
COMPRESSION RATIO 11:1
FUEL INJECTION
Lucas ECU Management
IGNITION System Type 468
OIL SYSTEM Dry Sump 1 Pressure pump
2 Scavenge pumps
COOLANT Circulated by centrifugal pump
STARTING Tilton geared cranking motor
ELECTRICAL SYSTEM Lucas 80 amp Alternator
  • 2 weeks later...
