Burned headlamp :(((
krisso_pl
I have burned my passenger side headlight trying to open it in the oven [sHOCK][/sHOCK]:complain::cry:
The inside of the lamp can be fixed but glass turned white in two places and is definitely dead.
Anybody have one spare lamp? Or maybe just the glass?
It was >97'
HEEEELPP :(
facelift?
Scotty> I have opened it before some time ago with no problems.It needed to be sealed again thats why I decided to open it again. 150 degrees for 10min...
I cook a pizza at that heat:d I guess looking for a set of used lights on the forum is a good bet now. I have a set that will be refurbed but they are not ready yet im afraid
Since you're in Poland, won't you be wanting a LHD headlamp? The UK/Jap ones are different so you might not find one easily on this board...
Fuck...you're right. My car is USDM...
Maybe someone here have US headlight... maybe... ?
Did you follow the guide on here? I have tried to warn people about the guide as the temp mentioned is far too high. 100 degrees is absolutely plenty. I personally go with 80 degrees for around 10 mins.
