Erratic idle and over boosting
retrostu
Hi,
got a tt that's had a few tweaks done to it prior to me purchasing it, which I know they included a pair of hybrid turbos.
used to go to 1.4 bar, but now idling high,
popping and boosting to 1.5 and cutting out.
Know there's probably a multiude of things it could be, But suggestions are welcome!
Done some more investigating and haven't as yet found any leaks, but have found some rather interesting changes.
For instance the idle control valve seems to have the two pipe of the bottom removed and joined together.
See for pics pipes missing
http://www.retromotors.co.uk/Images/Supras/idlemissing.JPG
and this is where they have been joined.
http://www.retromotors.co.uk/Images/Supras/Idlejoined.JPG
Also pipe on the turbo number 1 seem to have been removed from sensor and joined.
http://www.retromotors.co.uk/Images/Supras/turbojoined.JPG
Any ideas whats going on with this??
You need to get that car to a Supra specialist, stat. The pipes on the Idle valve are the water feeds, the VSV has clearly been bypassed because a) its fooked, b) a tuning biff has been at it or c) all of the above.
PS Where did you get your car from?
Yep I think thats the plan.
Why would the idle valve need coolant pipes?
Car came from a guy in Maidenhead area.
The work in the past was done by a company called Tuning Japanese in Aldershot, Hampshire.
