dandan Posted April 5, 2010 Share Posted April 5, 2010 OK guys, I am considering starting on a custom brake setup and have spent a bit of time of measurements/fitments etc but it's hard to commit to anything or make headwat without actual parts in front of me. I don't want to take my car off the road for three months while I work on this so I'm wondering if I should have a dummy setup for test fitting and development. I have spare suspension arms so now I'm thinking I should buy a complete front hub assemby and use that along with these arm to evaluate clearance etc. Does anyone have anything suitable? Cheers Dan p.s. I will also need something similar for the rear. (I'm not sure if it matters but my car is a 1996 facelift TT with bigger brakes from the factory) Link to comment Share on other sites More sharing options...
dandan Posted April 26, 2010 Author Share Posted April 26, 2010 Bumpy bump......... Link to comment Share on other sites More sharing options...
RobUK Posted April 26, 2010 Share Posted April 26, 2010 Hi Dan, I have a full sub frame.... if you can cope with the passenger side being mangled..... Cheers Rob Link to comment Share on other sites More sharing options...
Miguel Posted April 26, 2010 Share Posted April 26, 2010 Longshot, but Mr Harwood 'may' have some front and rear hubs knocking about. Shoot him a PM. Link to comment Share on other sites More sharing options...
dandan Posted May 11, 2010 Author Share Posted May 11, 2010 Hi Dan, I have a full sub frame.... if you can cope with the passenger side being mangled..... Cheers Rob Rob, Would you consider taking the upright/hub etc off the subframe? To be honest the whole subframe would be a real PITA for me and I really only need everything that is outside of the balljoints (upright/hub/drive flange etc) so that I can bolt my new discs to it and start fabricating a bracket to sit the caliper in the right place. Link to comment Share on other sites More sharing options...
RobUK Posted May 11, 2010 Share Posted May 11, 2010 Hi Dan, Shouldn't be a problem, the subframe is "in the bin" at the moment..... i'll try and have a look at it over the weekend for you... Cheers Rob Link to comment Share on other sites More sharing options...
dandan Posted May 14, 2010 Author Share Posted May 14, 2010 Longshot, but Mr Harwood 'may' have some front and rear hubs knocking about. Shoot him a PM. Thanks Mig - I did drop him a pm but no reply yet. Hi Dan, Shouldn't be a problem, the subframe is "in the bin" at the moment..... i'll try and have a look at it over the weekend for you... Cheers Rob Any luck yet Rob? Link to comment Share on other sites More sharing options...
RobUK Posted May 14, 2010 Share Posted May 14, 2010 Sorted it this morning... Do you want it sending or do you intend to collect? Cheers Rob Link to comment Share on other sites More sharing options...
dandan Posted May 14, 2010 Author Share Posted May 14, 2010 Good man Sending would suit me best mate as I'm not over your way any time soon. Is that going to be ok? Just to check, does it include all the bits circled in red in the pic? I don't suppose you have a back one as well do you? Link to comment Share on other sites More sharing options...
RobUK Posted May 18, 2010 Share Posted May 18, 2010 Hi Dan Yeah I can strip it back to just that part of you need it.... Cheers Rob Link to comment Share on other sites More sharing options...
dandan Posted May 19, 2010 Author Share Posted May 19, 2010 Good man - thanks. Do you have anything similar from either side at the rear? Link to comment Share on other sites More sharing options...
