northeast_supra Posted April 5, 2010 Share Posted April 5, 2010 I`m about to get a uk brake set for my NA (front and back) but i`ve had a look at the what wheels for uk brakes thread and have noticed i can get away with my wheels being 17x8 on the front but i've noticed the smallest wheels on the back is 17x9.5 and mine are 17x9 is there anything i can do to make them fit other than buy another set of alloys? or is it worth just leaving the rear stocks and having 4pots upfront? (now everyone can make fun after i sold my work miester 18"s ) Quote Link to comment Share on other sites More sharing options...
miko_supra Posted April 5, 2010 Share Posted April 5, 2010 What wheels you got? Quote Link to comment Share on other sites More sharing options...
northeast_supra Posted April 5, 2010 Author Share Posted April 5, 2010 A-tec 5 spokes 17"x8" on the front and 17"x9" on the rear Quote Link to comment Share on other sites More sharing options...
Supranature Posted April 5, 2010 Share Posted April 5, 2010 Small spacer? Quote Link to comment Share on other sites More sharing options...
Guigsy Posted April 5, 2010 Share Posted April 5, 2010 Forgive me. as i find these things a little confuseing. But from what i understand of it, is it not the offset that would be more important when trying to work out if uk brakes fit under the wheel? Although apparently the spoke design also plays a part. Simply getting wider weels might not cure the problem. There are plenty of wide 18" wheels that dont fit. Quote Link to comment Share on other sites More sharing options...
northeast_supra Posted April 5, 2010 Author Share Posted April 5, 2010 Forgive me. as i find these things a little confuseing. But from what i understand of it, is it not the offset that would be more important when trying to work out if uk brakes fit under the wheel? Although apparently the spoke design also plays a part. Simply getting wider weels might not cure the problem. There are plenty of wide 18" wheels that dont fit. i was thinking about the offsets aswell (although dont know a great deal about it) the alloys i have on at the moment dont have a deep dish.. well more of a little lip to be honest i think it would be a good mod if i dont have to change my alloys but if it does come to that might just get a new set of grooved and drilled disks front and rear with mintex pads Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted April 5, 2010 Share Posted April 5, 2010 (edited) The offset is the problem, the width of the wheel is not the problem as such. See if there is a member close to you that will let you test fit your wheel over there UK brakes. Other than that you have to try it and see. Also with 17's, the outside edge of the brake caliper will be very close to the rim, so if its a thick or curved rim you might have a problem there as well To give you an idea, mine were 18' and very close, I was very lucky http://www.mkivsupra.net/vbb/showthread.php?t=156527 Edited April 5, 2010 by DodgyRog (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted April 5, 2010 Share Posted April 5, 2010 The problem is that the larger 4 pot front brake calipers stick out a lot further than the smaller 2 pot calipers, this can cause clearance issues between the front face of the caliper and the back face of the spokes. The size of wheel needed to clear the caliper will vary depending on the design of the wheel, thickness of the spokes, shape of the spokes, width of the wheel and offset. Although the 2 pot rear calipers are a little wider than the smaller 1pot rears, it tends to be the fronts that are the main issues. As Rog suggested above, see if you can test fit your wheels on someone else's car with the larger brakes fitted. Quote Link to comment Share on other sites More sharing options...
northeast_supra Posted April 7, 2010 Author Share Posted April 7, 2010 just been to jm imports yesterday turns out they wont fit so just going to get some fresh discs all round and some good pads thanks for the help fellas Quote Link to comment Share on other sites More sharing options...
Guigsy Posted April 7, 2010 Share Posted April 7, 2010 get some braided lines fitted too Quote Link to comment Share on other sites More sharing options...
northeast_supra Posted April 7, 2010 Author Share Posted April 7, 2010 recommendations for discs, pads and lines? Quote Link to comment Share on other sites More sharing options...
Abz Posted April 7, 2010 Share Posted April 7, 2010 OEM discs with some Chris Wilson pads, don't forget to make sure you are using performance brake fluid. Does this mean the UK brakes are not going on? If not can I have them? Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 7, 2010 Share Posted April 7, 2010 Goodridge brake lines and Motul RBF 600 brake fuid, fitted to my car and 100% happy Quote Link to comment Share on other sites More sharing options...
northeast_supra Posted April 7, 2010 Author Share Posted April 7, 2010 Still with Keron i`m afraid had to check if they`d fit before going on as i dont want to change my wheels but he`s got a full setup going for a good price as i couldnt find any cheaper Quote Link to comment Share on other sites More sharing options...
Nic Posted April 7, 2010 Share Posted April 7, 2010 recommendations for discs, pads and lines? My choice would be stock OEM Toyota Discs, TRD black pads, Goodridge brake lines, TRD brake fluid and either a Cusco brake master cylinder brace or Carbing Tower bar with built in BMC brace. http://img210.imageshack.us/img210/7042/attachmentphpib1.jpg http://img46.imageshack.us/img46/2775/attachment1phpdh1.jpg Quote Link to comment Share on other sites More sharing options...
Guigsy Posted April 7, 2010 Share Posted April 7, 2010 how much are those stoppers nic? i had one on my old jspec car. and it worked a treat! I got one for my uk car but there was a load of other crap in that area and it didnt come with instructions so i couldnt see how to fit it :S Quote Link to comment Share on other sites More sharing options...
