my sidelights dont work ????
Supra N_A
Guest Budz86
If you're talking about the light at the outside of the cluster, it's a fog light. The one's on the inside are full beams, the one in the middle is dipped and there is a little one at the bottom between the dipped and fog which is the sidelight's.
If it's the fogs, there is a twisty 'ring' on the headlight stick attached to the steering column.
HTH
Edit: Picture added :)
Edited by Budz86 (see edit history)
hmmm right the full beam and dipped beam work but the foglights and sidelights dont work:(:( when i turn it once and the dash lights come on i suppose thats when the sidelights should come on and nothing. when i also turn the circle bit ON the headlight stick nothing aswell.
think it may be a blown fuse???
The other fusebox is under the steering column near the bonnet release btw.
Get a voltmeter and check there's power going to the sidelights, and get a battery and battery test your sidelights.
There's a relay somewhere which can go which gives the feed to the sidelights and I think the foglights as well.
And no you don't have facelift front lights, so in the front light cluster you have sidelights, dipped, main and fog lights
