Blackie Posted April 2, 2010 Share Posted April 2, 2010 Are they quite easy to fit or are they a pita? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 2, 2010 Share Posted April 2, 2010 They easy way is to fit a sandwich plate, or have you one already fitted? The hard way is to weld a fitting to the sump, and the temp will read about 5-10C less than a sender in the sandwich plate. Quote Link to comment Share on other sites More sharing options...
bluecoup Posted April 2, 2010 Share Posted April 2, 2010 its the sandwich plate that is a pita, id personally go remote on the oil filter at the same time Quote Link to comment Share on other sites More sharing options...
L33 Posted April 2, 2010 Share Posted April 2, 2010 looks like my sensor is drilled into the sump Quote Link to comment Share on other sites More sharing options...
Smoke_U Posted April 2, 2010 Share Posted April 2, 2010 Hi. Im not good at mechanics... whats going remote?? Where is the corekt placing of a oil temp sensor?? Thx! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 2, 2010 Share Posted April 2, 2010 its the sandwich plate that is a pita, id personally go remote on the oil filter at the same time You would still need to put a temp sensor in the take off plate, or you won't get a correct reading! Hi. Im not good at mechanics... whats going remote?? Where is the corekt placing of a oil temp sensor?? Thx! If you want accuracy then the sump is probably the most realistic location, but if your not over worried than go for a sensor in the sandwich/take off plate. Quote Link to comment Share on other sites More sharing options...
bluecoup Posted April 2, 2010 Share Posted April 2, 2010 remote moving oil filter to another location easier to change Quote Link to comment Share on other sites More sharing options...
Blackie Posted April 2, 2010 Author Share Posted April 2, 2010 Sounds like its a lot more hassle than its worth.Cheers all Quote Link to comment Share on other sites More sharing options...
Smoke_U Posted April 2, 2010 Share Posted April 2, 2010 ok thanks guise! Quote Link to comment Share on other sites More sharing options...
Stan Posted April 2, 2010 Share Posted April 2, 2010 I just gave my garage the sandwich plate and sensors (had pressure and temp put on at same time) and they charged me 3 hours labour, so depending on how much you wanna spend, you can get someone else to do it for ya!! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 2, 2010 Share Posted April 2, 2010 Don't know what all the fuss is about, its an easy job to fit a sandwich plate:search: Quote Link to comment Share on other sites More sharing options...
