Gaz Walker Posted November 27, 2002 Share Posted November 27, 2002 Has anyone any settings for a relatively stock car running an SAFC so I don't screw anything up when I install it... Regards, Gaz. Quote Link to comment Share on other sites More sharing options...
Ian C Posted November 27, 2002 Share Posted November 27, 2002 Yeah, zero across the range A relatively stock Supra should be fuelling correctly. The J-spec will measure up to 1.25bar (18psi) and theoretically has a fuel map for it (any experts on the stock ECU map in the house?) You'll need the AFC when you slap in yer 850's -Ian Quote Link to comment Share on other sites More sharing options...
Alex Posted November 27, 2002 Share Posted November 27, 2002 The stock ECU maps to 1 bar even though the sensor is capable of reading over that. The Mines ECU has a map to 1.1bar, apparently. So if running over 1 bar then any extra you can safely squeeze out at WOT may be of benefit....though I don't know how hard they run at WOT as standard. Quote Link to comment Share on other sites More sharing options...
adi Posted November 27, 2002 Share Posted November 27, 2002 Is the sensor embedded in the manifold or a seperate unit ie perhaps attached to the bulkhead? I could do with getting hold of one if anyone has one ? Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted November 28, 2002 Share Posted November 28, 2002 It's bolted to the side of the inlet manifold. Quote Link to comment Share on other sites More sharing options...
