no heat in my supra mkiv turbo
supra mkiv
hallo people.
after I installed new motor in my supra MKIV turbo, I can not get any heat in the car, what is the procedure by ventilating the radiator system?
I've tried to remove the radiator cap and made the car stand idle, but still no heat, some I keep it at 2000 rpm a little time I can feel the air coming out in the cabin, get warmer, but as soon as I release the gas, becomes cold shortly after.
what am I doing wrong
Guest beathacker
Had the same problem and that was because i had to litle water in it .. it helped when i just filled up the radiator after some idle
