Davey001 Posted March 30, 2010 Share Posted March 30, 2010 Can anyone tell me the rpm pinout on the ecu for a N/A? Quote Link to comment Share on other sites More sharing options...
Miguel Posted March 30, 2010 Share Posted March 30, 2010 Here you go: Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 30, 2010 Author Share Posted March 30, 2010 Which is rpm tho? Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 30, 2010 Share Posted March 30, 2010 When wiring an Apexi Neo the RPM sensor wire is connected to Pin # 58 if that is of any help to you Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 30, 2010 Author Share Posted March 30, 2010 thats what ive wired it in at but doesnt seem to be correct as its showing fault? Quote Link to comment Share on other sites More sharing options...
Miguel Posted March 30, 2010 Share Posted March 30, 2010 When wiring an Apexi Neo the RPM sensor wire is connected to Pin # 58 I vaguely remember it being either one of the ignitor pins (58 or 57). Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 30, 2010 Author Share Posted March 30, 2010 Can anyone say for definate? I wired into 58 but my emanage is showing a fault? Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 30, 2010 Share Posted March 30, 2010 (edited) Well my suggestion is from the Neo fitting guide, I'm afraid I can't be anymore help than that. http://www.mkivsupra.net/vbb/showthread.php?t=212583 Are you sure the other connections are in the correct place? Edited March 30, 2010 by pedrosixfour (see edit history) Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 30, 2010 Author Share Posted March 30, 2010 I think so, wired like this: a58 -rpm a43 - throttle a69 - ground b31 - live onlytwo wires i havent conected as it says they connect to volume airflow a66 but there is no pinout for it unless they go some where else?? Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 30, 2010 Share Posted March 30, 2010 There are two #31 pins as far as I can tell, the one you need (E10-31) is in the very bottom corner. E9-31 isn't used in the NA Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted April 1, 2010 Share Posted April 1, 2010 Did you have any luck with this? Quote Link to comment Share on other sites More sharing options...
Davey001 Posted April 1, 2010 Author Share Posted April 1, 2010 Yeah i think I have sorted out now, Thanks for your help mate! Quote Link to comment Share on other sites More sharing options...
