Branners Posted June 9, 2006 Author Share Posted June 9, 2006 also worth making sure your peak boost setting it set just right. The SBCID will lower the boost automatically if you go over the peak boost setting which is a great safety feature. I found I was 'just' hitting that peak boost setting so I tweaked it up a little and everything went fine from there. Im now a single turbo but not done anything about the boost settings until the car is mapped...one day perhaps. JB Link to comment Share on other sites More sharing options...
supra_surj Posted November 10, 2006 Share Posted November 10, 2006 I really dont understand these settings. ive got a jspec with all cats in. can someone give me the settings i should be using? also does it automaticaly use ch1, 2, 3 and 4 or do i select them so there showing on the display? sorry to sound abit thick. haha! Link to comment Share on other sites More sharing options...
Dragonball Posted November 10, 2006 Share Posted November 10, 2006 Give me a call and I will talk you through it... Link to comment Share on other sites More sharing options...
Sheefa Posted February 22, 2007 Share Posted February 22, 2007 Bump, I'm lost guys. I have used the following settings for a J-spec TT BPU with Hybrids: Channel 1: SET 20 GAIN 10 Channel 2: SET 25 GAIN 10 Channel 3: SET 35 GAIN 15 Channel 4: SET 60 GAIN 25 Despite this, I'm hitting no more than 0.76 bar and it wont go any higher. I do have an Induction kit fitted (previous owner) and the settings are all on MANUAL. What the frikking heck am I doing wrong? Thanks, Greg Link to comment Share on other sites More sharing options...
Sharpie Posted February 23, 2007 Share Posted February 23, 2007 You don't use a Power meter right ? So, if you leave it on CH4 at your current settings, you don't boost over stock ? Has it ever worked ? Sounds like you might need to check if it's installed right. Link to comment Share on other sites More sharing options...
Kn1ght Posted April 30, 2007 Share Posted April 30, 2007 After reading this link I’m still confused about how gain effects boost, as I understand it set is the % of extra boost above stock that the controller will allow through the turbos but what does gain do and how does it effect Boost? I was looking at my car's setup and the settings I have are Set = 35 and Gain= 3, the car will boost to 1.3 bar and spike up to 1.45 which is way to high for me, I don't want my Boost to go above 1.2bar. I have the old Miami GT stage 3 hybrids so I guess my new stock boost would be above 0.9 bar. What settings would people suggest? Link to comment Share on other sites More sharing options...
Lebsteif Posted May 18, 2007 Share Posted May 18, 2007 Kick would someone explain the top question please? I might think i should go for the AEM boostcontroller, the blitz got way too many functions! Link to comment Share on other sites More sharing options...
Sharpie Posted May 19, 2007 Share Posted May 19, 2007 HTH J SET = Boost Pressure/level Gain = Boost Resonse/Spool up Link to comment Share on other sites More sharing options...
Batmax Posted September 21, 2007 Share Posted September 21, 2007 Could some one put here setting for the J-spec why I can not use the uk settings ? Link to comment Share on other sites More sharing options...
Batmax Posted September 23, 2007 Share Posted September 23, 2007 No one ? Link to comment Share on other sites More sharing options...
Dragonball Posted September 23, 2007 Share Posted September 23, 2007 Could some one put here setting for the J-spec why I can not use the uk settings ? Say again? (sorry I am a bit slow today ) Link to comment Share on other sites More sharing options...
Pabs Posted April 9, 2008 Share Posted April 9, 2008 Guys, Sorry to drag this up, but I'm looking for some assistance. I have Paul E's old supra - and blitz idc boost controller. I'm seeing silly figures on boost peaks at the moment, and so want to get these reduced. The current settings are: I've checked the settings, and currently they are: CH1 Set=42, Gain=15, Limiter=55, Scramble=5 CH2 Set=40, Gain=15, Limiter=55, Scramble=5 CH3 Set=20, Gain=10, Limiter=55, Scramble=5 CH4 Set=15, Gain=5, Limiter=55, Scramble=5. I've gone for a blast down the motorway (about 10 mins ago) and I was seeing peaks of around 1.4bar when i put my foot down - I want this well below 1.15bar. I took ch1 SET down to 20, and I don't think I noticed much difference. I've also turned off scramble as I don't think I want/need it. Unfortunately I am a numpty with these things at the mo, still learning them. It seems to have a boost map, which I assume means that at different revs it uses different channel settings - correct? In which case, I should reduce ch2 and ch3 as well (ch4 isn't in use according to the map), as it'll be using these when i put my foot down (higher revs??) EDIT: It seems if I have it set to CH1, it will only use CH1. I need to flick to MAP to use all 4 channels as per map - so I shouldn't need to touch ch2/3/4 until I can get ch1 working right. Any help/guidance would be appreciated! Thanks Cheers folks Link to comment Share on other sites More sharing options...
Dragonball Posted April 10, 2008 Share Posted April 10, 2008 Paul The actual figures for the SET should approximate the % increase that you are looking to dial in above the stock figure i.e. if stock boost is 0.9 - and your SET figure is 40 = 0.9 x 40% increase = 1.26 BAR Of course it depends on your 'stock' boost figure, air density etc - and now it being colder drop this SET down to 30 0.9 x 30% increase = 1.17 BAR The GAIN figure it a similar increase dial in - although this will cause spikes if too high Take this GAIN down to 10 and see what happens (that is the beauty of the graphs available in the unit) Good testing! You are correct about the MAP figure - you will see this MAP may be configured according to either RPM's or speed (i.e. CH1, CH2. CH3 or CH4 settings will activate at those RPM's or MPH - depending on which you have chosen) Link to comment Share on other sites More sharing options...
saucyhot Posted April 10, 2008 Share Posted April 10, 2008 does any one have a good set of settings for my car. im a bit of a novice and mine got reset when i disconected the battery. My cars a jspec and full details are in my garage... please help Link to comment Share on other sites More sharing options...
supra_surj Posted April 10, 2008 Share Posted April 10, 2008 I understand how to work out the SET but how do you know what the GAIN should be? Link to comment Share on other sites More sharing options...
Dragonball Posted April 10, 2008 Share Posted April 10, 2008 I understand how to work out the SET but how do you know what the GAIN should be? Keep it below 20 Link to comment Share on other sites More sharing options...
supra_surj Posted April 10, 2008 Share Posted April 10, 2008 Cheers mate. Link to comment Share on other sites More sharing options...
Pabs Posted April 10, 2008 Share Posted April 10, 2008 Thanks Paul I think I'm going to reset ch1 (leave the settings for the other channels for now) and just start from the bottom and work up. I understand the theory of %, but don't understand why some cars need a SET of around 60/70 to get the same boost figure (1.2bar) as I would with potentially a SET of 20/30. Each car is different, agreed, but thats a big difference!.... How does the limiter figure come into play? Is it the higher the number, the quicker it reduces the boost??? Link to comment Share on other sites More sharing options...
Dragonball Posted April 10, 2008 Share Posted April 10, 2008 I understand the theory of %, but don't understand why some cars need a SET of around 60/70 to get the same boost figure (1.2bar) as I would with potentially a SET of 20/30. Each car is different, agreed, but thats a big difference!.... How does the limiter figure come into play? Is it the higher the number, the quicker it reduces the boost??? Me neither m8 - mine have always been Ok around those figures - unless there is a level beyond which it makes no difference Limiter figure - is the level at which the boost controller will attempt to retard the boost figure (this works only partially - it will flash red and you get a warning tone - you may feel a slight effect - but not a huge amount) Set this at 1.15 and you will be warned if you go over etc Link to comment Share on other sites More sharing options...
Pabs Posted April 11, 2008 Share Posted April 11, 2008 Set this at 1.15 and you will be warned if you go over etc I have the warning buzzer etc set at this value, as it was what you left it at However - the limiter value I am talking about seems to apply to all channels, and is a value between 0 and 100. This is next to the scramble setting. Currently it is set to 55?? I don't understand what this does and the manual doesn't really explain it. Link to comment Share on other sites More sharing options...
Dragonball Posted April 11, 2008 Share Posted April 11, 2008 I have the warning buzzer etc set at this value, as it was what you left it at However - the limiter value I am talking about seems to apply to all channels, and is a value between 0 and 100. This is next to the scramble setting. Currently it is set to 55?? I don't understand what this does and the manual doesn't really explain it. I always assumed this limits the SET figure - so no matter what you dial in it wil not go above this figure (a failsafe for un-nimble fingers perhaps) You will need to check this!! Link to comment Share on other sites More sharing options...
Pabs Posted April 11, 2008 Share Posted April 11, 2008 hmmm ok mate - thanks. I suppose you could be right - seems a bit weird, but could be! Link to comment Share on other sites More sharing options...
Pabs Posted April 13, 2008 Share Posted April 13, 2008 Right then - I went for a nice long drive today, and had the settings on CH1 @ SET 10, and Gain 10. Peaked at 1bar. So that's a good thing then. Cranked the SET up to 20 while on the move (manual says it takes affect straight away) and didn't really notice that much difference, maybe a peak at 1.04bar. Anyway - I'm much happier now that it's boosting lower, I'll just increase the settings until I'm happy. Thanks for your help peeps - especially Paul again! Link to comment Share on other sites More sharing options...
Guest Nizam Posted June 1, 2008 Share Posted June 1, 2008 im still look for two decat. anyone who selling please let me know Link to comment Share on other sites More sharing options...
kieren1234 Posted June 1, 2008 Share Posted June 1, 2008 im still look for two decat. anyone who selling please let me know And why did you feel the need to post that in this section?? Link to comment Share on other sites More sharing options...
