Graham S Posted March 29, 2010 Share Posted March 29, 2010 (edited) After much thought and very little arm twisting from Gav (JustGav), and countless pictures of what he has found etc... We have decided to start a project of our own... Its been a few years now since I sold my UK6 and i'm sure like all of us that have sold a supe that everytime the sun comes out I wish I was in it again...The sound of my old car driving away will haunt me forever (I'd never heard it before as no one got to drive it!). Anyway, Gav being Gav, he never really thinks lets build a car from normal parts, lets BUILD A CAR:eyebrows:. So, within a matter of days, we (well Gav) has sourced a shell, a silver manual shell that seems to be in very good condition and still has a good few parts attached, mainly steering rack, column, subframes etc. Last night we picked up a NA engine, to start playing with! Basically, plan is, on a budget of pretty much zero, we plan to build, starting from an NA (manual or auto is to be decided), which we want to build starting totally stock, to get a running car, then..... We have already aquired a GT4088, which we plan to run (NA-T), with a custom inlet, due to intake temp issues... but, using a stock block (bar 3mm head gasket and ARP's) and see just what the stock block will take. Obviously there are many many other things we have thought about but will go into that as it happens. So, project Leroy begins. (Leroy coming from Gavs wife, I think she has issues!! or dreams!) To follow will be a rather large shopping list, so if anyone has any parts they happen to have laying about give either of us a buzz.. Edited March 29, 2010 by JustGav (see edit history) Link to comment Share on other sites More sharing options...
Kirk Posted March 29, 2010 Share Posted March 29, 2010 Does gav have his finger in everything these days or what Ok 1st thing i noticed is 3mm HG... This is a big NONO.. will make far to much boost and will be a DOG on vac. Only 2 ways i would do it, either 1. TT HG or 2. TT pistons but not both as your CR will be lower than a TT and that isnt realy a good thing Personaly the ONLY way to drop CR correctly on an NA (unless you take a fair amount off the head) is through the piston and not the HG Thats my 2 cents Good luck with it anyway Link to comment Share on other sites More sharing options...
JustGav Posted March 29, 2010 Share Posted March 29, 2010 Leroy comes from this.... (Just for you Gray ) Qt0_oPPK6eA Captain Cowboy Link to comment Share on other sites More sharing options...
JustGav Posted March 29, 2010 Share Posted March 29, 2010 Does gav have his finger in everything these days or what Hahaha, not quite (I do still have a day job...) To be honest, Graham is the master with the spanners and chief builder, I'm the research and wiring guy... Ok 1st thing i noticed is 3mm HG... This is a big NONO.. will make far to much boost and will be a DOG on vac. Only 2 ways i would do it, either 1. TT HG or 2. TT pistons but not both as your CR will be lower than a TT and that isnt realy a good thing Personaly the ONLY way to drop CR correctly on an NA (unless you take a fair amount off the head) is through the piston and not the HG Thats my 2 cents Good luck with it anyway Might pick your brain about that actually, been researching a lot of the stuff DaveH did with his builds as he seemed to have a good measure of success. Some of the plans include getting rid of the dizzy (replacing with a coilpack setup), and going standalone... Link to comment Share on other sites More sharing options...
Graham S Posted March 29, 2010 Author Share Posted March 29, 2010 Does gav have his finger in everything these days or what Ok 1st thing i noticed is 3mm HG... This is a big NONO.. will make far to much boost and will be a DOG on vac. Only 2 ways i would do it, either 1. TT HG or 2. TT pistons but not both as your CR will be lower than a TT and that isnt realy a good thing Personaly the ONLY way to drop CR correctly on an NA (unless you take a fair amount off the head) is through the piston and not the HG Thats my 2 cents Good luck with it anyway More happy to listen to any suggestions / comments.. We are open minded! We basically got the 3mm HG idea from a site that built NA-T's and they basically put the compressions from 10:1 down to something like 8.4*:1. Now the option of shaving the head isn't a issue, we have a spare head and I can get the work done no problem.... If we knew what the exact amount to take off was, if of course thats possible.. Link to comment Share on other sites More sharing options...
Graham S Posted March 29, 2010 Author Share Posted March 29, 2010 Leroy comes from this.... (Just for you Gray ) Qt0_oPPK6eA Captain Cowboy dude, that song has been stuck in my head for bloody days! I ain't clicking that link! NOOOOOOOO way! Link to comment Share on other sites More sharing options...
Kirk Posted March 29, 2010 Share Posted March 29, 2010 Give us a shout anytime mate, been tinkering with NA engines for a while now. I followed DaveH to start with but i started speaking with 'suprarunner' as he had big success with his, he's now running around a 1000 with a full TT coilpack conversion with TT cam shaft postion sensor welded to the head and a TT oil pump with crank sensor and timing star, all that on a stock NA HG Link to comment Share on other sites More sharing options...
JustGav Posted March 29, 2010 Share Posted March 29, 2010 Got a polishing kit tonight and started having a go... Needs a few more goes over it, but was well chuffed ... Hmmm, might have to draw the line at what we polish though (Parts wise people!!! ) Link to comment Share on other sites More sharing options...
Spike3.0 Posted March 29, 2010 Share Posted March 29, 2010 What polishing kit did you get? I'm after one : ) Link to comment Share on other sites More sharing options...
JustGav Posted March 29, 2010 Share Posted March 29, 2010 What polishing kit did you get? I'm after one : ) Screwfix jobbie, came with 2 mop wheels and two bars. Dismantled the bench grinder and presto Link to comment Share on other sites More sharing options...
Graham S Posted April 9, 2010 Author Share Posted April 9, 2010 (edited) Ok people update time, We have drawn up a quick list of parts needed, so if any of you have any of these laying around please feel free to drop myself or Gav a PM.. Auto NA diff, prop and shafts Nearside (passenger) wing mirror, prefer silver if poss Both front wings , again prefer silver. Bonnet, silver is poss Offside (drivers) door handle NA manifold and either cats or decats Auto rad Rad cowling Headlights Indicators, both front and sides Rear lights Front seats/subframes Steering wheel Carpet Door cards Roof lining Pillars Instrument cluster, heater controls, fascia etc (for auto) Handbrake cables Complete brake setup Think there is probably much more but will update as we find out! Thanks in advance... Edited April 9, 2010 by Graham S (see edit history) Link to comment Share on other sites More sharing options...
Homer Posted April 9, 2010 Share Posted April 9, 2010 Got a silver bonnet, but it's a little damaged Got a pair of orange blob front and side indicators, 2nd cat and loads of other obscure parts. For info the NA auto & manual diffs are the same. I can probably get quite a lot of the stuff you asked for pretty cheap, let me know if you get stuck. Edit - instrument cluster too - the rpm dial has the auto plate (but will work fine on a manual). Also some of the control units and a few of the interior panels if required. Loads of looms including light ones, pretty much everything except the dash pair. Link to comment Share on other sites More sharing options...
caseys Posted April 9, 2010 Share Posted April 9, 2010 (edited) You have PM chaps. UK front lights (inc bulbs), UK rear lights (inc looms, no bulbs), set of UK front seats inc SFs, few bits n bobs. Let me know what you want from it all if you do and I'm sure we can come to some sort of deal. Edited April 9, 2010 by caseys (see edit history) Link to comment Share on other sites More sharing options...
j_jza80 Posted April 10, 2010 Share Posted April 10, 2010 I have a complete (I think, at least almost complete) set of interior trim plastics, a dash shell, cloth seats, door cards, rear qtr cards etc that you can have for free if you can collect from York. I also have a stock spoiler that I paid alot of money for from Michel Lane which you can have for free. This isn't an open offer for everyone, I just like the sound of this project and will donate them FOC if you can collect. I also have a broken headlight I was going to convert into a vent using fibreglass. Link to comment Share on other sites More sharing options...
JustGav Posted April 10, 2010 Share Posted April 10, 2010 I have a complete (I think, at least almost complete) set of interior trim plastics, a dash shell, cloth seats, door cards, rear qtr cards etc that you can have for free if you can collect from York. I also have a stock spoiler that I paid alot of money for from Michel Lane which you can have for free. This isn't an open offer for everyone, I just like the sound of this project and will donate them FOC if you can collect. I also have a broken headlight I was going to convert into a vent using fibreglass. Wow dude, don't know what to say but thanks I'll organise with Graham then a date to suit and we will make a trip up in the van... Gray and I once drove up to grimsby and back in one night for an engine a few years back, so York isn't as bad Link to comment Share on other sites More sharing options...
JustGav Posted April 10, 2010 Share Posted April 10, 2010 You have PM chaps. UK front lights (inc bulbs), UK rear lights (inc looms, no bulbs), set of UK front seats inc SFs, few bits n bobs. Let me know what you want from it all if you do and I'm sure we can come to some sort of deal. Cheers for the PM and yup, will be in contact soon Link to comment Share on other sites More sharing options...
JustGav Posted April 10, 2010 Share Posted April 10, 2010 Got a silver bonnet, but it's a little damaged Got a pair of orange blob front and side indicators, 2nd cat and loads of other obscure parts. For info the NA auto & manual diffs are the same. I can probably get quite a lot of the stuff you asked for pretty cheap, let me know if you get stuck. Edit - instrument cluster too - the rpm dial has the auto plate (but will work fine on a manual). Also some of the control units and a few of the interior panels if required. Loads of looms including light ones, pretty much everything except the dash pair. Superb, I'm sure Gray and I will chat with you next week during the pre-mot check Link to comment Share on other sites More sharing options...
j_jza80 Posted April 10, 2010 Share Posted April 10, 2010 Wow dude, don't know what to say but thanks I'll organise with Graham then a date to suit and we will make a trip up in the van... Gray and I once drove up to grimsby and back in one night for an engine a few years back, so York isn't as bad No problem, so long as it's all getting put to good use. Sooner rather than later if possible though Good luck with the project Link to comment Share on other sites More sharing options...
steady_dave Posted August 24, 2010 Share Posted August 24, 2010 Any update? That turbo looks hiyawge! Link to comment Share on other sites More sharing options...
JustGav Posted August 24, 2010 Share Posted August 24, 2010 Yes, there is a little bit of an update... Gray is currently away on hols but when he gets back he will hopefully have some pics of what is happening Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 24, 2010 Share Posted August 24, 2010 what are you planning for the cutome intake. im verry interested in thiss Link to comment Share on other sites More sharing options...
JustGav Posted August 30, 2010 Share Posted August 30, 2010 I'll let Gray post the update to this :) Link to comment Share on other sites More sharing options...
Kirk Posted August 30, 2010 Share Posted August 30, 2010 What a waste a post dude! Link to comment Share on other sites More sharing options...
JamieP Posted August 30, 2010 Share Posted August 30, 2010 The new car deserves a new thread imo;) Link to comment Share on other sites More sharing options...
JustGav Posted August 30, 2010 Share Posted August 30, 2010 The new car deserves a new thread imo;) And started by the new owner moving this one back to chat Link to comment Share on other sites More sharing options...
