Guest bigbenty Posted March 29, 2010 Share Posted March 29, 2010 Hi. I recently installed a wideband and some 650 cc injectors on my 93 jpec TT in preparation for a single turbo in the next year. I wanted to run with the stock twins for now with an AEM version two EMS. But when I took it for the install, my tuner said that the car had a MINES ECU in it and that it was a mess of wiring that was no longer stock. He said it would be a very big job to rewire it to stock and that I should just run with the MINES. The problem is, I have an upgraded pump and bigger injectors now, so I am overfueling. I need to get it tuned with this setup. Is there anyway to do this with the MINES ECU? Can I get software from somewhere to do this? Quote Link to comment Share on other sites More sharing options...
leelbuk Posted March 29, 2010 Share Posted March 29, 2010 You won't be able to tune that - that's why I'm stuck on 0.8bar at the moment as I have similar injectors The option you have are to use a piggy back such as e-manage, hks f-con etc or a standalone like the AEM you were originally going for. Not sure if either would be easier with the wiring however why was the wiring altered? The mines ECU should just be a factory ecu with only the innards changed slightly so should have bolted straight into the original loom? Quote Link to comment Share on other sites More sharing options...
