optim8 Posted March 29, 2010 Share Posted March 29, 2010 I did an airfield day at Colerne at the weekend. Couple of days before I got all my wheels rebalanced as I have for a while had a bit of steering shake around 75mph. Anyway when I got to the track, first lap was fine, second lap I got some steering wheel shaking under braking, and third lap was not nice at all:(. I ended up spending the day doing about 3 - 4 laps at a time and then leaving the car for 20 mins to cool down. Any suggestions what could be going on here? I'm running 17inch wheels, on stock UK Brakes. I have Nylon Spigot Rings fitted. Another thing that might be worth mentioning is I have had an o/s front knocking when going over bumps which has been checked by 2 different garages with nothing apparent found. Sub Frame bolts maybe? Incidently on the way home from Colerne anything above 60mph didn't feel too good either!! Quote Link to comment Share on other sites More sharing options...
Nic Posted March 29, 2010 Share Posted March 29, 2010 A worn wheel bearing or knackered brake disc can cause vibration under braking. Quote Link to comment Share on other sites More sharing options...
Angarak Posted March 29, 2010 Share Posted March 29, 2010 If it was a warped brake disc I'd have thought you would have felt the vibration through the brake pedal also. Quote Link to comment Share on other sites More sharing options...
