Guest aLLy_pl Posted March 29, 2010 Share Posted March 29, 2010 Hello i have a question , im building 1jz and i need to buy pistons for first stroke , I have easy access to 2jz pistons, can i use them in 1jz?? Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted March 29, 2010 Share Posted March 29, 2010 I would think the 2jz pistons would be too big as there for a 3 litre not a 2.5. I'm sure one of the other guys will give you a definite answer. Quote Link to comment Share on other sites More sharing options...
Tom Posted March 29, 2010 Share Posted March 29, 2010 (edited) yes you can, 2JZ Pistons should be fine as it's the stroke that differs between the 2, Edited March 31, 2010 by Ian C No unrequested pimping of wares in tech thanks (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest aLLy_pl Posted March 29, 2010 Share Posted March 29, 2010 Pistons have the same size , this 0.5 litre differnece between 2jz an 1.5 is because of height of block. But are they some other differences? Pistons are pretty expensive so i want to be sure thx for replies Quote Link to comment Share on other sites More sharing options...
garethr Posted March 29, 2010 Share Posted March 29, 2010 It's possible, for example, that the 1JZ and 2JZ conrods are different lengths, so, if nobody knows for certain, I guess you'd need to check if the 1JZ and 2JZ pistons are the same height above the gudgeon (wrist) pin, if the pins are the same size, and if the 2JZ piston skirt clears the 1JZ crankshaft. Quote Link to comment Share on other sites More sharing options...
stel Posted March 31, 2010 Share Posted March 31, 2010 I know the the jap boys are using the 2jz block with a 1jz head that works well. Quote Link to comment Share on other sites More sharing options...
Guest aLLy_pl Posted April 7, 2010 Share Posted April 7, 2010 Yes and im goin to do the same but atm i have to do it with 1jz block , but i have to be sure that i can use 2jz pistons. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 7, 2010 Share Posted April 7, 2010 If theres any doubt then just get 1JZ pistons. Quote Link to comment Share on other sites More sharing options...
