jevansio Posted March 27, 2010 Share Posted March 27, 2010 (edited) Been wanting to do one of these for ages so thought I'd document the process as I know you guys love pics First up pics of the engine bay. I already had a hole cut in the bay where I used to run my intake outside the engine bay. I moved it back into the bay as the filter got manky down there esp with no undertrays on. Another reason was the original hole wasn't cut very neatly & this is an opportunity to address this. I found some thick rubber with a checkerplate pattern. This is going to hold the end of the cold air feed, aswell as being flexible is easy to work with & fit. Here's a pic of it cut to fit the area the cold air box will cover, I've already inserted part of the feed. The entire feed is made of 4" sections of drainage pipe I got from B&Q. The first piece is a 90deg join, I just drew round the end on the rubber checkerplate & cut a hole for it. Here you can see it sweeping down & to the left. Next is a 45 deg angle which aligns the end perfectly with the opening in the front bumper. The great thing is these pipes push together like lego and have a built in rubber seal which gives a great OEM feel to the whole setup A quick pic looking down showing both ends of the intake feed To support the end of the intake I made a bracket to attach it to the bodywork. I used a bracket that is normal used to support the drainage pipe away from walls (it sort of wraps around the pipe & has 2 legs on), and added my fixing (an alluminium plate) to attach it to the body The last bit was to use a pipe joiner (again from B&Q, all the bits I used could be purchsed from their "drainage section") which flared the end of the pipe open to suit the bumper vent better. It basically looked like a funnel which attached on the end of the 4" pipework A final pic showing what it looks like from outside, pretty subtle Will get onto doing the box next, not sure whether to use aluminium sheet or smoked perspex? Edited March 27, 2010 by jevansio (see edit history) Quote Link to comment Share on other sites More sharing options...
Geo Posted March 27, 2010 Share Posted March 27, 2010 Nice and Simple Jay. Im sure there will be loads of cold air going into that then, think it will make a diiference though?? Quote Link to comment Share on other sites More sharing options...
jevansio Posted March 27, 2010 Author Share Posted March 27, 2010 Cheers George, once I get the box made I think it will (esp in the hotter days). It def feels quicker today though, I use my performance box to check the cars performance, midweek it showed 492rwhp, today it showed 506rwhp. The best one was fitting new plugs that went from 470rwhp to 492. So in total the car has picked up 36rwhp from the various things I've fixed/changed over the last week or two (even though the ambient temps have been rising day after day) Quote Link to comment Share on other sites More sharing options...
nigelboyne Posted March 27, 2010 Share Posted March 27, 2010 lovely work what mileage are you changing plugs Quote Link to comment Share on other sites More sharing options...
Geo Posted March 27, 2010 Share Posted March 27, 2010 Cheers George, once I get the box made I think it will (esp in the hotter days). It def feels quicker today though, I use my performance box to check the cars performance, midweek it showed 492rwhp, today it showed 506rwhp. The best one was fitting new plugs that went from 470rwhp to 492. So in total the car has picked up 36rwhp from the various things I've fixed/changed over the last week or two (even though the ambient temps have been rising day after day) What the hell is that?? Quote Link to comment Share on other sites More sharing options...
jevansio Posted March 27, 2010 Author Share Posted March 27, 2010 It's a Racelogic Performance Box, a GPS based device used to do such things as time 0-60, 30-130, 1/4mile (or any thing you want timing), accurate to 0.1sec. Enter the weight of the car & it'll also provide a calculated power figure based on what power is needed to accelerate a given mass at that rate. It's prolly not accurate enough to put against other dyno readings (although it does seem pretty bang on for me considering I was last dynoed at 640 flywheel), but it's great for checking the effectivness of mods against each other on the same car as if it's inaccurate, it'll be the same % out for both runs Quote Link to comment Share on other sites More sharing options...
Geo Posted March 27, 2010 Share Posted March 27, 2010 It's a Racelogic Performance Box, a GPS based device used to do such things as time 0-60, 30-130, 1/4mile (or any thing you want timing), accurate to 0.1sec. Enter the weight of the car & it'll also provide a calculated power figure based on what power is needed to accelerate a given mass at that rate. It's prolly not accurate enough to put against other dyno readings (although it does seem pretty bang on for me considering I was last dynoed at 640 flywheel), but it's great for checking the effectivness of mods against each other on the same car as if it's inaccurate, it'll be the same % out for both runs Mmmmm interesting, iv still to install RLTC in mine had it sitting for ages, might see about the add on then. cool mate thanks Quote Link to comment Share on other sites More sharing options...
jevansio Posted March 27, 2010 Author Share Posted March 27, 2010 Mmmmm interesting, iv still to install RLTC in mine had it sitting for ages, might see about the add on then. cool mate thanks You don't need RLTC for the PB, it's a totally seperate box, have a look in for sale, Wez has one going Quote Link to comment Share on other sites More sharing options...
Brazil Posted March 27, 2010 Share Posted March 27, 2010 You write some fantastic threads...! Thanks for taking the time to post it up...! Quote Link to comment Share on other sites More sharing options...
Geo Posted March 27, 2010 Share Posted March 27, 2010 You don't need RLTC for the PB, it's a totally seperate box, have a look in for sale, Wez has one going Im on it cheers Quote Link to comment Share on other sites More sharing options...
jevansio Posted March 27, 2010 Author Share Posted March 27, 2010 You write some fantastic threads...! Thanks for taking the time to post it up...! Thanks, no probs at all Quote Link to comment Share on other sites More sharing options...
devan Posted March 27, 2010 Share Posted March 27, 2010 Jevansio; i like how youve mounted your HID Ballast, but how is it secured down, as i cant see the bracket for it? Quote Link to comment Share on other sites More sharing options...
jevansio Posted March 27, 2010 Author Share Posted March 27, 2010 Jevansio; i like how youve mounted your HID Ballast, but how is it secured down, as i cant see the bracket for it? NoMoreNails - on a roll, they're stuck solid Quote Link to comment Share on other sites More sharing options...
devan Posted March 27, 2010 Share Posted March 27, 2010 Ok good idea lol, ill look at mounting mine there when they arrive, cheers. Quote Link to comment Share on other sites More sharing options...
themodifiedkid Posted March 27, 2010 Share Posted March 27, 2010 Another quality post to run along side your fmic ducting thread. Nice one mate very informative, im impressed:thumbs: Quote Link to comment Share on other sites More sharing options...
Stonkin Posted March 27, 2010 Share Posted March 27, 2010 Good work there mate, well done Quote Link to comment Share on other sites More sharing options...
Kirk Posted March 28, 2010 Share Posted March 28, 2010 You inspire me to copy every last thing you do Thats some nice install mate Quote Link to comment Share on other sites More sharing options...
jevansio Posted March 29, 2010 Author Share Posted March 29, 2010 Many thanks guys Made the template for the box yesterday, decided to make it so it can take a lid so it is totally enclosed, I think I'm going to use the aluminium sheet rather than lexan sheet Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted March 29, 2010 Share Posted March 29, 2010 I think this is going to be a very nice job when finished. Quote Link to comment Share on other sites More sharing options...
Mas Posted March 29, 2010 Share Posted March 29, 2010 Looking good mate, seems like thats what I need to finish of the cones I have in front of my bumber PLUS: do the headlights fit without problem with your balast fitted there mate?! Ive got 3 on each side and running out of ideas where to put them Quote Link to comment Share on other sites More sharing options...
jevansio Posted April 1, 2010 Author Share Posted April 1, 2010 Cheers guys, Sorry for the late reply Mas, the headlights fine perfectly, they actually help make the balast such a snug fit under them they pretty much hold them in place (although I used adhesive to hold them also) Update: The aluminium turned up this week, I still hadn't decided if I was going to make a box that sealed with the bonnet or a fully contained box. I quite liked this one by uk-rich so set of making my own: To determine the distance to the bonnet I used my RC car aerial and measured how much it squashed at various positions I re-made a card template using this info, but due to the fact I couldn't guarantee an airtight seal (it was rather an unusual shape & the bonnet skin & frame weren't air tight) I went with the sealed box idea. I made each side seperately and will join them with some aluminmium angle later. Here's the main side cut & in place I reattached the card side to ensure everything was aligned & well And the sides taped together & in place More tomorrow Quote Link to comment Share on other sites More sharing options...
Geo Posted April 1, 2010 Share Posted April 1, 2010 Nice work Jay. That coupled with the Air intake from underneath should help loads. Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted April 1, 2010 Share Posted April 1, 2010 Fair play, looking very good. Quote Link to comment Share on other sites More sharing options...
glenn Posted April 1, 2010 Share Posted April 1, 2010 (edited) jay, i havent for got you, with regards to meassurments, was called away with work.will pm you tomorrow morning, with sizes.if you still need them Edited April 1, 2010 by glenn (see edit history) Quote Link to comment Share on other sites More sharing options...
jevansio Posted April 1, 2010 Author Share Posted April 1, 2010 Cheers guys, No probs Glenn, TBH I'm going with the sealed box approach so they're prolly not going to be much use to me anyway, I'm hoping to have it finished tomorrow Quote Link to comment Share on other sites More sharing options...
