Lude Posted March 26, 2010 Share Posted March 26, 2010 every car/japanese turbo ive had have always had crap heaters, only get sorta luke warm, and are never very strong. ive got water temp gauge, and the car gets to 80 degrees fine, and always holds it at that. is it the thermostat, heater matrix, or does the supra just have crap heaters also? will have a go at bleeding on the weekend just incase, Quote Link to comment Share on other sites More sharing options...
JamieP Posted March 26, 2010 Share Posted March 26, 2010 (edited) Heater matrix is most likely blocked, mine gets red hot, i cant hold my hand infront of it on high. Edited March 26, 2010 by JamieP (see edit history) Quote Link to comment Share on other sites More sharing options...
Lude Posted March 26, 2010 Author Share Posted March 26, 2010 woops wrong section, can it be moved to tech please? matrix blocked - is that common? Quote Link to comment Share on other sites More sharing options...
Steve Posted March 26, 2010 Share Posted March 26, 2010 Moved Quote Link to comment Share on other sites More sharing options...
Scott Posted March 26, 2010 Share Posted March 26, 2010 Yeah its common that they get gunky. Good idea to disconnect the in and out flow pipes and hose out the matrix itself from the top of the engine. Just use a garden hose on a reasonable flow, nothing crazy. Let it run until the crap coming out, stops coming out Quote Link to comment Share on other sites More sharing options...
Lude Posted March 27, 2010 Author Share Posted March 27, 2010 Yeah its common that they get gunky. Good idea to disconnect the in and out flow pipes and hose out the matrix itself from the top of the engine. Just use a garden hose on a reasonable flow, nothing crazy. Let it run until the crap coming out, stops coming out thanks mate, is there a pic of which pipes im looking at in the engine bay? put water in them isit? Quote Link to comment Share on other sites More sharing options...
Terminator Posted March 27, 2010 Share Posted March 27, 2010 Should be quite a few pic on here. It may be worth doing twice, once to get it freed up and a second time after using a proprietary water system cleaner.Then put in Forlife and keep an eye on the colour and change it when it loses is deep red colour. Be prepared for the matrix to have suffered damage as corrosion can speed up under a thick layer of gunk. Quote Link to comment Share on other sites More sharing options...
Lude Posted March 27, 2010 Author Share Posted March 27, 2010 (edited) http://www.mkivsupra.net/vbb/showthread.php?t=181288&page=3 http://www.mkivsupra.net/vbb/attachment.php?attachmentid=102975&d=1261488634 Edited March 27, 2010 by Lude (see edit history) Quote Link to comment Share on other sites More sharing options...
gavin.starr Posted March 28, 2010 Share Posted March 28, 2010 as Scott M said do it twice. Flush it out with the garden hose, then plumb back together run with some rad flush, then use hosepipe again, drain the lot and re-fill with toyota red for life coolant. Then you will just have to wish that the matrix hasnt rotted/correded where the gunk was, as its a pig of a job to replace, ive done it and wouldnt want to do it again for love nor money. Gav Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 29, 2010 Share Posted March 29, 2010 Yep, these original matrices are old now, flushing, pressurising, even adding fresh anti freeze can give them a shock that results in a very expensive leak. Be prepared for a potential big bill or a LOT of DIY work if you start flushing the thing. Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted March 29, 2010 Share Posted March 29, 2010 may have a airlock, take of your rad cap and let the car get to normal temp then obv put your rad cap back on worked for my GT when i also changed my matrix:d Quote Link to comment Share on other sites More sharing options...
