Kristian_Wraae Posted March 25, 2010 Share Posted March 25, 2010 What will need to be removed / added to a Eurospec 2JZ-GTE in order to run it with a japspec harness and ecu? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 26, 2010 Share Posted March 26, 2010 I will add what I can. The second O2 sensor become redundant. The injectors are different sizes and impedance. One use an air flow meter, the J-Spec uses aMAP sensor, so modding will be needed to the loom for that. Probably quite a bit more, I hate looms, wiring and all that stuff One of the cams is different duration in a UK spec engine, but it will make sod all difference really. Least of your worries. mapping won't be ideal though,especially given the smaller UK turbos. Quote Link to comment Share on other sites More sharing options...
