nigelboyne Posted April 1, 2010 Author Share Posted April 1, 2010 can the hks evc 6 boost controller read the afrs mate or is a seperste gauge needed Link to comment Share on other sites More sharing options...
Homer Posted April 1, 2010 Share Posted April 1, 2010 can the hks evc 6 boost controller read the afrs mate or is a seperste gauge needed You'll need a seperate gauge and wideband O2 sensor mate Link to comment Share on other sites More sharing options...
nigelboyne Posted April 1, 2010 Author Share Posted April 1, 2010 thanks mate best stop putting E85 and xylene in till i get the gauge Link to comment Share on other sites More sharing options...
Homer Posted April 1, 2010 Share Posted April 1, 2010 Eeek, you've been using E85? How much %age wise? Have the lines, pump and map been adjusted for it? That stuff need a lot of mods to use in any quantity. Link to comment Share on other sites More sharing options...
nigelboyne Posted April 1, 2010 Author Share Posted April 1, 2010 10 liters to a fill Link to comment Share on other sites More sharing options...
Homer Posted April 1, 2010 Share Posted April 1, 2010 That's a fair amount. All I'd recommend is to use pump fuel and start troubleshooting from there. You absolutely must have an AFR (or at minimum an EGT) gauge in place before raising boost. Without either you have no idea if you have potential det issues. Link to comment Share on other sites More sharing options...
Lude Posted April 2, 2010 Share Posted April 2, 2010 You'll need an AFR gauge, it's an essential item when running over stock boost level. think im going to get one after reading that, im just nto comfortable my increased boost, and fueling controlled with a Apexi SAFC Link to comment Share on other sites More sharing options...
Guest alan3579 Posted December 4, 2010 Share Posted December 4, 2010 stop the high boost pulls then. or they (turbos) wont last much longer. there safe up to 1.4 bar 1.5 bar i can live with but 1.6 is prob to high. I would never push them to 1.4 bar with no fuel management or AFR gauge IMO you think they are safe at 1.5 bar? i wouldnd put stock twins over 1.2 bar if i had any intentions of them staying on my car. UK twins.... can we have some form of closure on this: can the uk spec turbos deal with 1.4 bar??? Link to comment Share on other sites More sharing options...
Nic Posted December 4, 2010 Share Posted December 4, 2010 (edited) can we have some form of closure on this: can the uk spec turbos deal with 1.4 bar??? The turbos themselves *may* run 1.4bar fine - the weak point on the UK turbos tends to be the oil seals. If you do run 1.4bar, you need to know what the air/fuel ratios are, you don't want it running lean at high boost pressures - for this you will need an AFR gauge. You also need to know what the exhaust gas temperatures are - for this you will need an EGT gauge. Without being able to monitor the AFR's and EGT's you could be risking your engine. Edited December 4, 2010 by Nic (see edit history) Link to comment Share on other sites More sharing options...
Guest alan3579 Posted December 4, 2010 Share Posted December 4, 2010 Thanks Link to comment Share on other sites More sharing options...
Ian C Posted December 4, 2010 Share Posted December 4, 2010 Even so you may still get detonation during long pulls just because of the amount of heat being put into the air charge under those boost levels. A dyno run or three while listening for detonation would be a good idea Apexi AFC, by the way, isn't going to help with an otherwise stock setup. Once you're defeating fuel cut, i.e. running 1bar+ of boost, your injectors will be at 100% duty cycle. Doesn't matter how much more airflow signal you try and pump in with the AFC under those circumstances - especially as it's then clamped to about 4.4volts by the fuel cut defender. Link to comment Share on other sites More sharing options...
Terminator Posted December 4, 2010 Share Posted December 4, 2010 (edited) I would pull back to 1.2bar until you can sort out AFR gauge and EGT gauge. I would be surprised if you have not already had some degree of detonation by spiking at 1.7 bar. Once you have caused det, the little dings in the piston form nasty little sharp edges on the piston surface that heat up quickly and create hot spots and can induce det at lower temperatures thus increasing the chance of further detonation. Edited December 5, 2010 by Terminator (see edit history) Link to comment Share on other sites More sharing options...
BABZ988 Posted December 4, 2010 Share Posted December 4, 2010 Even if i think you're pushing the luck ;Sound once more that the 2JZ-GTE is a Maad engine AFR gauge & ( i.e ) AEM FI/C would be a good solution ! Link to comment Share on other sites More sharing options...
