Any plasteres on here?
miko_supra
Artex "can" be removed with a decent steamer, but its a PITA of a job, and the ceiling may have been tex'd from new, in which case it won't have been skimmed prior.
Cut away the affected area to the nearest joist, patch-board in the same thickness, then your plasterer can skim the lot in. Artex really needs skimming over tbh, assuming youe ceiling is ok.
I dont move in till the start of next month, so I don't know the full extent of the damage, I shall have to see.
Platerboard is cheap mate, just screw another layer over the top with 50mm drywalls and re skim it.
What sort of price do you reckon it would cost to do all this for a room that is 3mx4m?
Edit: Do you mean putting new board over the top of what is already there?
(I'm a complete noob at all this btw)
Yes new board over what is there will be fine.
Labour/materials £200 would cover it id say, if you get the materials there i might be able to lend you Danial one saturday (if he is up for it) you would have to pick him up from high wycombe, just give him a £100 and help him hold the boards up while he screws them and he will skim it.
Cool :) I will probably take you up on that offer if he's up for it!
I'm a plasterer
would sort you a good price pal but Its a bit far from Nottingham to Buckinghamshire !lol
as jamie says the best way would be to overboard & skim
or cut out the damaged part & re board then Pva and re skim the whole lot! The artex shouldn't need to come off as it doesnt look very heavy so should skim over fine:d
