Twin Walbro's Vs Bocsh 044 Fuel Pump
Geo
044's run in tank in countless single seaters with no issues at all. It is just a higher flowing version of myriads of similarly designed Bosch pumps, many of which run in tank in thousands of road car. Can't see why there could be an issue? Unless you need a swirl pot and the associated complexity a single 044 in tank makes a nice sanitary installation and you know if it stops, as the engine will, too. With dual pumps you may run lean if one croaks.
