L33 Posted March 24, 2010 Share Posted March 24, 2010 well after coming home today and seeing all my gauges and cd player on and the car locked and armed i decided to investigate and found the power cables going into the little white connector were half hanging out and touching each other i tried to fix it but had no luck and the white connector isnt holding the little crimp things inside so fooked . i found one website that sells repair parts but with no pictures, it says the defi link control unit power supply cable...now my question is would that come with the white connector already attached that plugs into my control unit? or literally just the cable i will ring them in the morn but wondered if any one here knew i put the coloured cables (red, black, orange and white) back into the holes in the white connector they came from (took a pic so there was no mistakes ) and now and again the gauges lit up, the radio wont turn off and the heater control panel doesnt work im hoping it will be all ok when i have a new connector as i think things are touching inside. my radio didnt actually turn off when all the cables were pulled out the connector so had to remove the cd faceplate which is odd and not happened before! when i touched the orange and red cables from the connector together the heaters worked, and my boost controller and afr gaugue, but not if i stopped touching them so guess thats power in and out. PITA on the up ive had r888s fitted on the back and loads of new shiney stuff in the engine , slam panel cooling plate on its way o and bought a grommet for the rear wiper where mine has perished, getting there this month Quote Link to comment Share on other sites More sharing options...
