Steve Posted May 21, 2005 Share Posted May 21, 2005 Am thinking of adding HKS Cams to my J spec Supe. Is this a worth while mod? Whats the going rate to fit a set of these cams? (if i had the cams already) Thanks Link to comment Share on other sites More sharing options...
Ian C Posted May 22, 2005 Share Posted May 22, 2005 What sort of HKS cams...? -Ian Link to comment Share on other sites More sharing options...
Steve Posted May 22, 2005 Author Share Posted May 22, 2005 264's Link to comment Share on other sites More sharing options...
Supragal Posted May 22, 2005 Share Posted May 22, 2005 Won't be 264's if you end up with mine Link to comment Share on other sites More sharing options...
Steve Posted May 22, 2005 Author Share Posted May 22, 2005 Ok then if i get Supragals cams. 256 and 264's Better Link to comment Share on other sites More sharing options...
Supragal Posted May 22, 2005 Share Posted May 22, 2005 tee hee Link to comment Share on other sites More sharing options...
Nic Posted May 22, 2005 Share Posted May 22, 2005 smarty said: Am thinking of adding HKS Cams to my J spec Supe. Is this a worth while mod? Whats the going rate to fit a set of these cams? (if i had the cams already) Thanks Been reading your spec in your sig, yes these would be a worth while mod, you'll feel a 'some' extra power between 4000-6000 rpm with your current spec. The real benefits though will come once you have done the other mods on your to do list ie. fueling, IC and e-manage then you will see bigger gains from having the cams fitted. Link to comment Share on other sites More sharing options...
Ian C Posted May 22, 2005 Share Posted May 22, 2005 Biggest difference I noticed was over 6000rpm, it just keeps pullin'. The idle goes a bit lumpy too -Ian Link to comment Share on other sites More sharing options...
Steve Posted May 22, 2005 Author Share Posted May 22, 2005 Thanks guys Rosie will let you know. Link to comment Share on other sites More sharing options...
Steve Posted May 22, 2005 Author Share Posted May 22, 2005 Sorry one more thing. Are they easy to fit or is it best left to someone with more knowledge? Link to comment Share on other sites More sharing options...
Fox Posted May 23, 2005 Share Posted May 23, 2005 smarty said: Sorry one more thing. Are they easy to fit or is it best left to someone with more knowledge? Good question!! I'm hoping to get me some HKS Cam's also and was going to try and do the jobie my self. Any help or advice on fitting cam's Link to comment Share on other sites More sharing options...
Guest Terry S Posted May 23, 2005 Share Posted May 23, 2005 are you happy checking and if necessary re shimming? Link to comment Share on other sites More sharing options...
Fox Posted May 23, 2005 Share Posted May 23, 2005 Erm!!! I have got me some new spanners and a left handed screwdriver!! Link to comment Share on other sites More sharing options...
Steve Posted May 23, 2005 Author Share Posted May 23, 2005 Terry, did you get my PM about the work i need doing and maybe the fitting of these cams? Need to get it sorted. Link to comment Share on other sites More sharing options...
Guest Terry S Posted May 23, 2005 Share Posted May 23, 2005 will check now Link to comment Share on other sites More sharing options...
