HKS Cams
Steve
Am thinking of adding HKS Cams to my J spec Supe.
Is this a worth while mod?
Whats the going rate to fit a set of these cams? (if i had the cams already)
Thanks
Been reading your spec in your sig, yes these would be a worth while mod, you'll feel a 'some' extra power between 4000-6000 rpm with your current spec. The real benefits though will come once you have done the other mods on your to do list ie. fueling, IC and e-manage then you will see bigger gains from having the cams fitted.
Sorry one more thing.
Are they easy to fit or is it best left to someone with more knowledge?
:cool:
:yeahthat:
Good question!! I'm hoping to get me some HKS Cam's also and was going to try and do the jobie my self.
Any help or advice on fitting cam's
