Powersteering leak??
Guest suprabass
Guest suprabass
Ok was bleeding the powersteering on the car earlier following all instructions from write ups on here.
system was bleeding fine left to right but on the left lock it would let out a whine, after a few goes and bubbles etc gone from the tank, I gave it another lock to th left it let out a big whine and then stopped.
Knocked the car off and went to investigate, noticed fluid had sprayed everywere (light mist) but there was also drops on the floor. so after some looking I could see it dripping down the brace from what looks like the pressure feed tube, so cleaned it up and started the car up again let it idle and gave it another lock to lock. Turned off and came back to another few drops on the ground. and some spray in the engine bay.
Now Im stuck to what it could be?? could it be just the gasket on the pressure feed tube and need tighted or is it more sinister???:(
Thanks
Guest suprabass
Not that I could see, I was getting to the point hunger was winning and gave up for the day lol.
Just looking for more info or suggestions,
