Bill Prawn Posted May 21, 2005 Share Posted May 21, 2005 Quarry Bend at Castle Combe today. He was trying hard and caused some entertainment for the gathered crowd. Quote Link to comment Share on other sites More sharing options...
sooper-supra Posted May 21, 2005 Share Posted May 21, 2005 yp lol was ray sent off because i saw the marshalls talking to him about summit! Also boneyard (dale) wasnt aloud on was he because of his loud exhaust? Quote Link to comment Share on other sites More sharing options...
Branners Posted May 21, 2005 Share Posted May 21, 2005 caused some entertainment for the marshalls as well, car 54 come in, your time is up, your bung fell out. JB Quote Link to comment Share on other sites More sharing options...
Bill Prawn Posted May 21, 2005 Author Share Posted May 21, 2005 This one fell out? I can't believe that Very Heath Robinson Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted May 21, 2005 Share Posted May 21, 2005 Haha Quote Link to comment Share on other sites More sharing options...
Matt T Posted May 21, 2005 Share Posted May 21, 2005 Lol, i noticed that 'bung', lol Did he really get black flagged for drifting? Cos Phil with the Driftworks s14a was doing it on every corner Quote Link to comment Share on other sites More sharing options...
Branners Posted May 21, 2005 Share Posted May 21, 2005 Lol, i noticed that 'bung', lol Did he really get black flagged for drifting? Cos Phil with the Driftworks s14a was doing it on every corner nah, he got picked off for noise, they got their pointy stick out when they pulled him in and measured the noise again. Dont know what the final figure was but I bet it was way more than 99db....non-turbo with decat and exhaust is never going to be quiet. JB Quote Link to comment Share on other sites More sharing options...
Ian R Posted May 21, 2005 Share Posted May 21, 2005 Was behind Ray on track with Colsoop video on the baffle/bung blue peter job came out on the first corner entering the pit lane. They pulled him off and was reading 128db OOH thats loud !!! Quote Link to comment Share on other sites More sharing options...
MARTIN R Posted May 21, 2005 Share Posted May 21, 2005 You were behind the N/A then Ian ?? Quote Link to comment Share on other sites More sharing options...
Ian R Posted May 21, 2005 Share Posted May 21, 2005 Yep getting footage and could keep up with Ray!!! Had 19's on and wasn't to keen on hammering it into corners and coming home on a low loader Quote Link to comment Share on other sites More sharing options...
Bill Prawn Posted May 22, 2005 Author Share Posted May 22, 2005 They pulled him off ! Added extras of the track session. I wish i'd have signed up. Quote Link to comment Share on other sites More sharing options...
Geezabloke Posted May 22, 2005 Share Posted May 22, 2005 Wish id have signed up for the track session too.... You guys were lucky to get out after and before the rain........ What happened to Behave's car? did he spin at far end or have problems, it sounded great on the straights but he kept chamging places when round for the next lap? Great day out guys Dave Quote Link to comment Share on other sites More sharing options...
Pete Posted May 22, 2005 Share Posted May 22, 2005 The best way to temporarily reduce noise is a little trick I used for SVA. You need wire mesh and loads of wirewool/scouring pads (coarse). Create a sausage the same size as the exhaust width filled with these and insert into the rear. You'll need to expand the wire into a part of the exhaust so it won't shoot out (as mine did first SVA!!). It's better if you can get it further up the pipe really, I ended up welding a nail in the centre to prevent it from flying out. Quote Link to comment Share on other sites More sharing options...
Lazarus Posted May 22, 2005 Share Posted May 22, 2005 What happened to Behave's car? He pulled over onto a disused part of the track for a few seconds to play about with something on the car (from inside), blipped the throttle a couple of times then went off again by that time a few had passed. Quote Link to comment Share on other sites More sharing options...
b_have Posted May 22, 2005 Share Posted May 22, 2005 Not sure what happened, cabin filled with smoke at the end of the straight! stopped on the infield, temp/oil press/Egt/ all normal. Set off again, fine or another 2 laps then clouds of smoke again in the mirror so retired. Again all guages showed normal. Found oil dribbling from the gearbox/engine bellhousing and getting onto the exhaust so guessed it was either rear crankseal or G'box/TC seal. Problem was the oil was red (same as type 4 atf and the silkolene engine oil i use!) so not sure where it was coming from. Anyway, checked the levels and they showed full so drove home with no further problems. Maybe i overfilled something? Very strange! Quote Link to comment Share on other sites More sharing options...
SimonB Posted May 22, 2005 Share Posted May 22, 2005 Not sure what happened' date=' cabin filled with smoke at the end of the straight! stopped on the infield, temp/oil press/Egt/ all normal. Set off again, fine or another 2 laps then clouds of smoke again in the mirror so retired. Again all guages showed normal. Found oil dribbling from the gearbox/engine bellhousing and getting onto the exhaust so guessed it was either rear crankseal or G'box/TC seal. Problem was the oil was red (same as type 4 atf and the silkolene engine oil i use!) so not sure where it was coming from. Anyway, checked the levels and they showed full so drove home with no further problems. Maybe i overfilled something? Very strange![/quote'] I've got some video footage from when I was following you round the track, you were smoking quite badly just before I came past you on the straight. I'll try and post it up tomorrow then you can see for yourself! Quote Link to comment Share on other sites More sharing options...
b_have Posted May 23, 2005 Share Posted May 23, 2005 Cheers Simon, would like to see that. Quote Link to comment Share on other sites More sharing options...
