surpra alarm... wierd??
DBR
Hi all, quick question......... got my suup bout 2 months ago now and was told the alarm wasnt working and that they have unplugged it because it had blown the printing circuit board............(and therefore was given no alarm fob.)
BUT.... i left the window open an locked up the car with key yesterday, returned to the car and opened from the inside door handle and THE ALARM WENT OFF???...........
i checked the engine bay and from what i can see the alarm is unplugged? (alarm, bottom right nxt to battery, uk spec) could this mean i have got both the toyota alarm and an aftermarket alarm fitted........ any ideas how i can check alarm/immob. is working prop. on either......... if it is working is it just a case of getting a new fob from toyota............
your help please guys this one is puzzleing me.
cheers
Guest Rash
Im pretty sure what you heard could have been the backup siren sounding that is behind the dash i think.. The standard UK Supra alarms have caused quite a bit of trouble and many of them are now knackered... My last supra alarm had to be disconnected to get the car to start again after the car battery went flat...
Rash.
Also the alarm/immobiliser probably still works via the key.......hence it sounded off after you locked it.
Rash.
alright rash how u doin' m8, cheers for the info........ if alarm is still working via key doies that not mean it is still working ok? can i just get the alarm fob an be on may way!........ i remember you having some probs with with black suup u had...... was this the same case with yours??
