Thor VFCC
MarkR
This stops the fuel cut when you go BPU and the car hits the built in boost limit. See here for description: http://www.mkivsupra.net/vbb/showthread.php?t=35932
and here for settings:
http://www.mkivsupra.net/vbb/showthread.php?t=9916
It's currently setup for my VVTI facelift car.
£50 delivered (buyer pays fees if using paypal)
Branners has first dibbs but if he's not interested then whoever is next. These are rare as they're not made anymore and work perfectly without affecting anything else adversely. I had no problems and ran this for 6 years.
...But TheModifiedKid also had one of these for sale recently if that helps.
Thanks for the info Branners, but it looks as though TheModifiedKid's VFCC has already sold.
I actually bought a brand new Greddy BCC a while ago (not fitted yet), but I was under the impression that a Thor VFCC may be a little better. It would seem though, that the upper boost cut feature on the Thor is around 1.25 Bar, so it wouldn't be any good for me if I want to run my UK Spec turbos at a slightly higher level than that. On the face of it, it looks like I probably wouldn't be gaining anything with a Thor VFCC over the Greddy BCC with having a UK spec...
I thought the THOR was fully adjustable? I plan on running up to 1.3bar on a cold day.
I better look in to it.
The Thor definitely has an upper limit somewhere in the region of 1.25 Bar, but I'm not certain if you can disable this upper limit altogether - in which case, I don't think you're gaining anything over the Greddy BCC.
