3800 Hi Stall Torque Converter - SWAP ONLY !!
Jamesy
Hi guys
I am picking up my Boostlogic autobox in the next week or so. :D
Its coming with a 3800 Hi Stall which is probably a bit high for my turbo (GT35R).
..... so i just wondered if anyone has a smaller Hi Stall (what is the lowest available? :search: ) that they might want to swap for mine if they are running a big turbo?
If not, no worries....
Muchos! ;)
Is stock not around that?
I thought i read stock was 1800 but you know me mate ... NO idea lol.
does anyone know what the lowest hi stall converter available is?
With a GT35R coming on boost so early i was told i need to go for a low Hi Stall :blink:
I don't understand what you are looking for though bud. The reason for the 3800 stalls is so that you are at max boost when the car takes off. Any lower and it won't shoot the same.
If you take it down past 3k you aren't going to get much of a launch benefit and you would be as well with stock ;)
Just from what i'd heard if the turbo comes on at 2000 rpm, would i really want a hi stall keeping the revs at 3800 after every gear change on WOT? granted on launch then yes ideal, but not after every gear change
therefore not gaining the benefit of the early spool.
i thought the 3800 hi stall were better suited to bigger turbos which kick in around 3500-4000 rpm
i hope i understand the function of this properly lol :search:
Think you need to do some reading bud. I'm not claiming to know anything about them but my understanding of it all is as follows...
The stall size determins the the amount of revs that can be applied while braking, this spools the turbo ready for launch. This means that you can push the accelerator to 3.8krpm for a perfect launch. The lower you go the more off boost you are for launching (depending on turbo size). With the 35 I would guess 3krpm-ish would be good for a launch. Any less and the turbo will most likely stall. I think the 35 is hitting max boost by around 3.5k so that would work out perfect as a compromise.
I don't think the converter will make any difference to WOT gear changes as you will be well past the 3.8k mark (upwards of 7 depending on the ECU map).
IMO I think you should try it without the aftermarket converter to see what you think. After that you can do the old swaperoo if you wish.
I don't think the way it changes gears on WOT is affected. The main thing that people tend not to like is the way it drives when pottering around.
Due to the torque converter being a higher stall it takes more revs for it to bite (as i understand it). This means that your engine is revving up to 2k before going anywhere and when it bites I'm guessing it will bite with authority.
The higher stall you go, the higher you can rev with your foot on the brake. The obvious downfall is described above as the biting point will also increase, causing notchy, jerky gear changes.
Yes because the torque converter changes where the bite is in order to raise the power brake limit.
Think of the area between the bite and the brake limit as a band. The higher one goes, the higher the other goes.
But if your not 'power braking' and driving normally would it still need all those beans to grt it moving?
Will need to do some proper research on this!!!
You have 2 diff stalls dude, flash stall ie driving along on tickover and flooring it, this will be the highest and brake stalling ie power braking off the line and building rpm/boost, this will be lower than the other, the gentler you are with the throttle the less it will stall, for the umpteenth time you need a 3400 min stall converter.
Sorry to dissapoint but gt35r's come on at around 3K unless your using an ultra small exhaust housing and if you are, your then strangling the engine, i have run over 5 supra's with GT35r's and they are generally on full boost by 3500 to 4k and start boosting around 2600-3000rpm depending on housings, on a 2JZ you want the a/r .82 if you want less power or the 1.03 (more power) i think it is, (what i use)
The Stock t/c suits a 35r well, however a 3800 will out launch a stock one on any turbo no matter how small the turbo is, don't forget you can feather the throttle to drive in a more refined matter, you can get the stock t/c to drive at around 1k with a light touch. :)
Mines a .68 dude, cheers ;)
