Ebay Link: Mercedes Benz (MB v7.4) Carsoft Diagnostics Tools and Software Package
Pudsey
My Ebay sales thread just incase anyone is interested: -
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300408864403&_trkparms=tab%3DSelling
This sale is for: -
Mercedes Benz (MB v7.4) Carsoft Diagnostics Tools and Software Package.
Including: -
(USB 2.0 to RS232 9-Pin & 25-Pin Serial Port Adaptor with Software).
This provides you with everything you need to diagnose problems/ fault find on your Mercedes-Benz at home with the use of a PC, rather than pay expensive rates at the dealer.
Reason for Sale: -
I bought this tool in Feb 2009 as the picture above displays to service my Mercedes-Benz W202 - C43 AMG, prior to putting it up for sale.
I ended up part exchanging the car with a dealer prior to the sevice indicator coming on, and hence never used the tool for purpose I bought it for.
None of the leads have been taken out of the bags they came in, so nothing has been connected at all physically as never been used.
I did load the software to my PC and set everything up, which gave me the opportunity to look through the package and options etc. (Drop down windows similiar to Work or Excel very easy to use).
It was never tested as you need to connect the leads and R232 Module to the cars ECU, OBD 2 Port to pull through information etc.
Where I bought the package: -
The package was purchased from UK-CAR-DIAGNOSTICS for the sum of £97 (Including postage Recorded Mainland UK)
I purchased the USB 2.0 to Serial Port Connector and Leads from Ebay for £10 (Including postage Standard Rate Mainland UK).
As far as I can be aware the package is in working order its all new as discribed, just I have never actually used it to be able to confirm completely.
What you will get exactly as pictured above: -
1 x Mercedes-Benz (v7.4 MB) Carsoft Diagnostics Package as supplied by UK-CAR-DIANOSTICS in Feb 2009.
Software Leads x 5 (OBD 2 - 38 Pin and 14 Pin leads) and Instructions 1 x CD for loading to PC, is all contained on the CD provided by the original supplier in a handy purpose designed storage bag supplied.
Software will work on Microsoft XP, 2000, ME, 98, Windows NT.
1 x USB 2.0 to R232 Serial Port adaptor (9-Pin & 25-Pin) with 1 x Software CD for multiple computer applications as above.
The Mercedes Range it will work with: -
The Mercedes-Benz Package lists the following Mercedes-Benz cars, so its fully compatible.
Personal Cars.
W168 (A-CLASS), R170 ( SLK), W208 (CLK),W209 (CLK), W202 (C-CLASS). W203 (C-CLASS), W210 (E-CLASS, W211 (E-CLASS),
W140 (S-CLASS), W220/W215 (S-CLASS), R129 (SL), R230 (SL)
Commercial.
VITO-(V-CLASS), SPRINTER.
Off Road Vehicles.
G463, W163
The above are all listed within the software showing what the package covers, so virtually all the range up to 2008.
Functions of the software and capabilities: -
I have written down all of the functions on the within the drop down menus below, and have taken some screen grabs I can email if necessary copied into a Word Document.
This will be for your information only, I will not enter into dialog outside of the Ebay rules( So all questions/ comments directed back through Ebay please).
Digital Diagnosis.
Complete Diagnosis Option.(So runs a systems check)
Lists :- HFM/PMS, ME, MSM, DFI, CDI, LH ENGINE 104/119, LH ENGINE 120, ABS/ASR/ETS, TRACTION/ESP, AIRBAG, BAS, SAM, HRA, DCM, ESA, EGS, AIRMATIC/ABC, AIRCO, PSE, PTS, OCP, LCP, UCP, D2B, ELS, RVS, AAM, EAM, KG, SBC, FFZ/FBB, VD, INSTRUMENT CLUSTER.
Error Erase Codes for the above listing.
Analogue Diagnosis: - As above and includes the same error erase functions.
Special Functions: -
Service Reset, Service Interval Adjustment, Live Data Coding, Active Adaption Erase, CDI Injector Test.
I would suggest that I have been as honest and descripive as humanly possible with this sale, certainly more so than when I even purchased the package.
Posting and Packaging: -
I will package the items carfully and securely in a water proof membraine, wrapped tightly with fragile tape.
I will be sending the items by Recorded Delivery to the UK Main Land Only in the price indicated.
(Anything else will require additional fees and postage check on my part to ensure everything is covered, but you will pay I am affraid).
Price: -
You will pay the packaging and posting as indicated, and also my Ebay fees will be included the sale price.
I will be setting a reserve price as you can clearly see what it cost me, but you will get a bargain there is no doubt.
Happy Bidding..................
Any Questions at all or anything I can help with please ask.
I will endevour to answer all questions as accurately as possible to the limits of my technical (enthusiast's) ability.
Thanks for looking.
