GRIM Posted March 18, 2010 Share Posted March 18, 2010 (edited) Hello guys Car is '97(NON-VVTi) JDM Supra TT 6sp. mods at the moment of testing were: Mine's ECU TRD Ver. S catback (2.5-3"") HKS Midpipe 3" TRD filter in stock airbox HKS SSQV stock SMIC 1st cat in place BCPR7ES plugs (gap not touched, should I ?) no boost controller Here's the result: http://img684.imageshack.us/img684/2745/img978.jpg http://img715.imageshack.us/img715/7699/img979.jpg car was tested in 3rd gear the result is in WHP (~300whp) I just don't like the power loss after 150km/h is it normal? anyone have stock or bpu supra DYNO RESULT? I don't know what boost it was at and I have no boost controller so I hope it was stock boost but who knows ((( Edited March 18, 2010 by GRIM (see edit history) Quote Link to comment Share on other sites More sharing options...
TooColdToDrive Posted March 18, 2010 Share Posted March 18, 2010 I got 283whp in my 93 TT JSpec auto, with a catback exhaust, and a restrictor ring restricting boost to 9-10 pounds. Quote Link to comment Share on other sites More sharing options...
Lude Posted March 18, 2010 Share Posted March 18, 2010 (edited) hi mate, um, i think that is a bit low, but i think your problem is the cat still in place, and what level of boost your running. heres a dyno run of mine, similar mods, exhaust, filter, FMIC, double decat, restricotor ring, FCD. boost is 1 bar, but i dont know if this graph is based on 1 bar or 1.2. 381 BHP Edited March 18, 2010 by Lude (see edit history) Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted March 18, 2010 Share Posted March 18, 2010 hi mate, um, i think that is a bit low, but i think your problem is the cat still in place, and what level of boost your running. heres a dyno run of mine, similar mods, exhaust, filter, FMIC, double decat, restricotor ring, FCD. boost is 1 bar, but i dont know if this graph is based on 1 bar or 1.2. http://i181.photobucket.com/albums/x169/lude200/dyno1.jpg 381 BHP Thats a fly figure though not a Wheel BHP Quote Link to comment Share on other sites More sharing options...
GRIM Posted March 18, 2010 Author Share Posted March 18, 2010 Thats a fly figure though not a Wheel BHP Yeah I see but I'm curious about my power drop after 150km/h as I see from others dyno result it's not normal can it be a vacuum/boost leak? Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted March 18, 2010 Share Posted March 18, 2010 (edited) Yeah I see but I'm curious about my power drop after 150km/h as I see from others dyno result it's not normal can it be a vacuum/boost leak? 299 bhp at the wheels on stock SMIC is not too bad on an old car, it will be running out of puff and thats why the power is dropping off, need to see the RPM range to be sure Remember its a 3rd gear pull so terminal speed will be lower Edited March 18, 2010 by tooquicktostop (see edit history) Quote Link to comment Share on other sites More sharing options...
GRIM Posted March 18, 2010 Author Share Posted March 18, 2010 299 bhp at the wheels on stock SMIC is not too bad on an old car, it will be running out of puff and thats why the power is dropping off, need to see the RPM range to be sure Remember its a 3rd gear pull so terminal speed will be lower what do you mean ? don't have rpm range ((( Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted March 18, 2010 Share Posted March 18, 2010 what do you mean ? don't have rpm range ((( 3rd gear pull on stock boost,stock tubbies and an old SMIC will see power peak as the turbos reach optimum level then power will drop off slightly, this will also be exaggerated if you SMIC is tired Without a RPM figure the power drop could just be the mapper/garage letting off the gas as RPM's reach peak, its hard to say Dont worry too much on dyno figures mate, I still say 299 WHP on a stock SMIC,boost and tubbies is a good result with the first CAT still in Quote Link to comment Share on other sites More sharing options...
GRIM Posted March 18, 2010 Author Share Posted March 18, 2010 (edited) tooquicktostop, thanks mate The guy who tested my car told me that it was in 3rd gear but now looking at the speed it doesn't look like it's in 3rd in 3rd gear max speed is 148km so it can't be in 3rd right? Now I have removed the first cat and replaced it with a 3" downpipe I don't have restrictor ring because it's not overboosting, max seen is 1 bar at higher gears/speed btw, should I re-gap the plugs? I have no idea what's the stock gap on BCPR7ES??? Or maybe it's better to change them to BKR7E and gap to 0.7-0.8mm? Edited March 18, 2010 by GRIM (see edit history) Quote Link to comment Share on other sites More sharing options...
