another HID XENON Kit problem ..it doesn´t work, is there a second fuse anywhere?
Guest Tisi
I mounted my HID Xenon Kit yesterday, it doesn´t work, after them i put the halogen lamps back again ...
and now... even no light,... :(
I checked the fuse in the fuse box near the battery, but everthing is OK...
What can I do??
Is there anywhere another fuse for the light ???
I know as I use a HID Kit in my GSX-r1000 bike, I had to replace the 10A fuse through a 20A, cause the 10A fuse were blown every time I´d turn on the ignition...
Please help me...
I mean, disconnect the HID ballasts and reconnect regular bulbs to the oem connectors, OR measure the voltage at the OEM harness to make sure you have 12V there.
Troubleshoot 1-0-1: Eliminate possible error prone parts of the situation and test basic setup. Then add one part a time and check.
- also a good idea to switch the plugs around to check thats not the issue
I had reconnected the regular bulbs,.. but theres nothing....
another strange feature is that the main beam doesn´t work to.... only fog lamp will work....
I should measure the stock harness...
I measured the voltage ---> 0,0V ...
Does the supra have a light relay which can be defect?
Or a light controller box?
Because I only change the dipped beam.. and now there no main beam.....
that must be a heavier thing than a fuse..or?
yes under bonnet every fuse is ok,.. and yes I looked to the fuse boy in the foot space at the driver side.. but on the cover theres no beam/light fuse shown.... :(
