foggy147 Posted March 17, 2010 Share Posted March 17, 2010 Grrrr, since taking the car for a 30 mile drive yesterday due to the battery being flat and jump started.The car has been stood over night and just gone to start it and its flat again!!Not checked the fuse for the stereo yet as the the ariel and stereo stopped working since being started.Sems the battery isnt holding its charge. The battery was perfectly fine before I let it lose its charged once the car had always started first time evertime so I dont think its a battery problem. Is their a fuse that controls charge getting to the battery? As when it did start yesterday it idled lower than normal when stood still so seems the charge wasnt great?Any advice or help would be appreciated Quote Link to comment Share on other sites More sharing options...
supra steveo Posted March 17, 2010 Share Posted March 17, 2010 check to see if the alternator is charging the battery first , also it mite just be a simple new battery coz the battery is in a state of deep discharge and will never hold a charge again, it sounds like a you need sa new alternator tho its a fairly easy job too Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 17, 2010 Author Share Posted March 17, 2010 what do i need to check it?like i say it was perfectly fine until i left lights on evernight and it went flat. The ariel and stereo dont come on which is probably the fuse. Could it possibly be anything else?how much are the alternators? Quote Link to comment Share on other sites More sharing options...
Guest argy911 Posted March 17, 2010 Share Posted March 17, 2010 (edited) try a hydrometer . Edited June 30, 2010 by argy911 (see edit history) Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 17, 2010 Author Share Posted March 17, 2010 If the battery has flame arester vents unscrew all 6 of them .Then get someone to crank the engine a few times while you look at the battery water for bubbling. If you see any bubbling the battery has had it. Do you mean where you fill the top holes of the battery with ionised water or somewhere else? Quote Link to comment Share on other sites More sharing options...
Guest argy911 Posted March 17, 2010 Share Posted March 17, 2010 Do you mean where you fill the top holes of the battery with ionised water or somewhere else? Thats the ones. Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 17, 2010 Author Share Posted March 17, 2010 Thats the ones. Thanks will check that inmorning. Is there any chance it could be a fuse as i read that there would be a fuse that controls the battery circuit so if thats blown that could be why?like i say when i ot tstarted it did idle low Quote Link to comment Share on other sites More sharing options...
Guest argy911 Posted March 17, 2010 Share Posted March 17, 2010 Thanks will check that inmorning. Is there any chance it could be a fuse as i read that there would be a fuse that controls the battery circuit so if thats blown that could be why?like i say when i ot tstarted it did idle low Not sure about that , You'll have to ask the guys with expierence on the forum . Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 17, 2010 Author Share Posted March 17, 2010 Like I say the car does start when jumped so it aint like it's not starting at all, it's just like it's not holding charge or something Quote Link to comment Share on other sites More sharing options...
supra steveo Posted March 18, 2010 Share Posted March 18, 2010 have you tried beeping your horn ? if the battery is knackered the horn will die , it sounds like the battery has had it either way , if you can manage to get the engine started and check the voltage on the battery if i am right should read 13 volts ,i wait to be corrected here lol if the alternator is knackered let me know changing it is fairly easy but a bit of a pain if you dont know how to Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 18, 2010 Author Share Posted March 18, 2010 How would you check for the alternator being knackered? Quote Link to comment Share on other sites More sharing options...
stevie_b Posted March 18, 2010 Share Posted March 18, 2010 Can you borrow a trickle charger from anyone? If so, put the battery on trickle charge for maybe 24 hours, and see if it can hold a charge for longer than 2 or 3 days. If it can't, then you're sure to need a new battery. If it can, then maybe the alternator's at fault. Quote Link to comment Share on other sites More sharing options...
Guest Suprafly Posted March 18, 2010 Share Posted March 18, 2010 If you can get the car started take it to any garage and they'll test your battery and charge from the alterator in about 5 minutes. Also have you checked your crank pulley? Quote Link to comment Share on other sites More sharing options...
merckx Posted March 18, 2010 Share Posted March 18, 2010 Isn't there a warning light that will come on if it's not charging properly? Much more likely to be the battery I would think. Quote Link to comment Share on other sites More sharing options...
leelbuk Posted March 18, 2010 Share Posted March 18, 2010 Sounds like a dead battery to me If something is wrong with your charging circuit you would usually see the battery indicator light up in the car, but you can check anyway by reading the voltage of the battery - it should increase from 12 to ~14 volts whilst the the car is started & reved a little. A battery check is free in most places like halfords etc. so worth a check there maybe? Batteries can die quicker than you think too. I replaced mine 3 weeks ago as it seemed fine (was starting my car ok the day before) but then it refused to take charge. Was wierd since it had enough charge in the battery to start the car many times the day before, even with stop/start sort of runs so it pointed to the charging circuit/alternator suddenly failing, however the voltmeter test proved otherwise. Just to point out as well - this battery was less than 18 months old. Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 18, 2010 Author Share Posted March 18, 2010 (edited) Ok thanks for all your help guys, My cousin is coming to pick up battery tonight to take to work to put it on a trickle charge overnight and to test the battery. Will see what it comes back with if it is something wrong id rather it be the battery than anything else Edited March 18, 2010 by foggy147 (see edit history) Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 19, 2010 Author Share Posted March 19, 2010 Yay just been round with a new 150quid power battery lol, started the car instantly and now the radio comes on so must of been the battery didnt even have enough power to start the radio. All back up ad running again can start enjoying the Supra!!Thanks guys! Quote Link to comment Share on other sites More sharing options...
stevie_b Posted March 19, 2010 Share Posted March 19, 2010 Yay just been round with a new 150quid power battery lol, started the car instantly and now the radio comes on so must of been the battery didnt even have enough power to start the radio. All back up ad running again can start enjoying the Supra!!Thanks guys! Glad that it's working again. How did the old battery perform after getting trickle-charged? Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 19, 2010 Author Share Posted March 19, 2010 Glad that it's working again. How did the old battery perform after getting trickle-charged? Im still waiting to find that out will know later. Figured a new battery wouldnt do it any harm either way. It's a big yellow battery it's mainly made to power high spec cars as in big ICE installs so this one could probably power 3 supras lol Quote Link to comment Share on other sites More sharing options...
stevie_b Posted March 19, 2010 Share Posted March 19, 2010 Ahh, OK. There's a small chance that your old battery will be fine once it's been trickle-charged for a while, but my money's on a duff battery too. On the offchance that it's the charging circuit in the car that's at fault, you'll be in the same situation in maybe a month or two with a shiny new battery that doesn't have enough power to start the car. Quote Link to comment Share on other sites More sharing options...
foggy147 Posted March 19, 2010 Author Share Posted March 19, 2010 Ahh, OK. There's a small chance that your old battery will be fine once it's been trickle-charged for a while, but my money's on a duff battery too. On the offchance that it's the charging circuit in the car that's at fault, you'll be in the same situation in maybe a month or two with a shiny new battery that doesn't have enough power to start the car. Well fingers crossed the test on the battery come back rubbish then so it explains it. If not is there a way I can check the circuit before it would even get to the point to be sure or is that the alternator that would need sorting? Quote Link to comment Share on other sites More sharing options...
stevie_b Posted March 19, 2010 Share Posted March 19, 2010 Not sure TBH: I'm not familiar with the charging circuit so can't really advise. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 19, 2010 Share Posted March 19, 2010 Have you got a multimeter? Engine off should be just under 12 volt, running it should be well over, about 13.8 maybe? Quote Link to comment Share on other sites More sharing options...
supra steveo Posted March 19, 2010 Share Posted March 19, 2010 make sure your alternator is ok too otherwise you will just of wasted £150 anyone got a bit of extra advice on how to check this? i cant remember Quote Link to comment Share on other sites More sharing options...
supra steveo Posted March 19, 2010 Share Posted March 19, 2010 Have you got a multimeter? Engine off should be just under 12 volt, running it should be well over, about 13.8 maybe? or is this the advice i am looking for ? Quote Link to comment Share on other sites More sharing options...
