dmx75 Posted March 16, 2010 Share Posted March 16, 2010 hello people!! Well for some reason my passenger door has decided to stop opening. It seems the handle inside is either jammed or god knows, i was trying to open the door yesterday for around an hour but i just cant get it open. Does anyone have the same problem or have any idea how to fix it? Any help would be great. Link to comment Share on other sites More sharing options...
ellis Posted March 16, 2010 Share Posted March 16, 2010 Broken cable? I'd take the panel off (if you can) and peek inside. Link to comment Share on other sites More sharing options...
Guest Lizzy Borden Posted March 16, 2010 Share Posted March 16, 2010 Just had a Soarer in with a similar problem. Turned out to be the micro switch on the lock barrel. The wires had become twisted together and frayed. Every time you pulled the handle the door locked, and as soon as you flicked the switch to unlock it just re-locked. (trapped for 2 mins lol) Link to comment Share on other sites More sharing options...
dmx75 Posted March 16, 2010 Author Share Posted March 16, 2010 thats the thing i cant get the door open to take the panel off!! so not sure how to get the panel off to have a look. Can take the panel off around the handle, where the lock an handle is but thats about it! Link to comment Share on other sites More sharing options...
merckx Posted March 16, 2010 Share Posted March 16, 2010 This happened to me once on another vehicle, the door wouldn't open at all I cut through the door striker using a hacksaw blade in the small gap between the door and the rear wing. Minimal damage, the striker was cheap and easy to replace Link to comment Share on other sites More sharing options...
