Davey001 Posted March 14, 2010 Share Posted March 14, 2010 Hi just wondering if anyone can help me with installing emanage blue to mysupra N/A got the guide for a TT but the pinouts seem diffrent! Cant seem to see some of the wires on the ecu harness! Anyone got a Ecu pinout diagram for a N/A ? ASAP!! Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 14, 2010 Author Share Posted March 14, 2010 Any help out there? wanted to getthis in today! Quote Link to comment Share on other sites More sharing options...
supspower Posted March 15, 2010 Share Posted March 15, 2010 Think i have somewhere will check when i get home later. Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 15, 2010 Author Share Posted March 15, 2010 Think i have somewhere will check when i get home later. Cheers mate any help would be greatfull at the minute! Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted March 15, 2010 Share Posted March 15, 2010 here we go mate , this is the pinout i used to fit mine http://images.google.co.uk/imgres?imgurl=http://home.online.no/~bertilen/artimages/2JZ-GE_ECU2.jpg&imgrefurl=http://www.performancemotorresearch.co.nz/forum/showthread.php%3Ft%3D24&usg=__ewXX8SkWHszbbmCtwqbb4lOJW7o=&h=922&w=664&sz=148&hl=en&start=9&itbs=1&tbnid=eO6Sm3yczeRaDM:&tbnh=147&tbnw=106&prev=/images%3Fq%3D2jzge%2Bpin%2Bout%26hl%3Den%26safe%3Doff%26gbv%3D2%26tbs%3Disch:1 Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 15, 2010 Author Share Posted March 15, 2010 Ok cheers mate! So that brown rpm on the ecu does go to 58 igniter! Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 21, 2010 Author Share Posted March 21, 2010 Hey can anyone help, Got all wires installed now apart from 2 but i dont think I need them for mine can anyone correct me if iam wrong? Green + White wire into pinout 66 mass airflow sensor? My N/a doesnt have that pinout so no massairflow sensor? so do i need to connect these wire to anything? Any help would be greatfull before I put everything back Quote Link to comment Share on other sites More sharing options...
Ian C Posted March 21, 2010 Share Posted March 21, 2010 Well have you got a MAF? If yes, then you need it, if not, then you don't. Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 21, 2010 Author Share Posted March 21, 2010 No maf, just a map sensor which just plugs in. So are there wires just taped up and not used? Quote Link to comment Share on other sites More sharing options...
Ian C Posted March 21, 2010 Share Posted March 21, 2010 Yep Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 21, 2010 Author Share Posted March 21, 2010 Cheers mate! All done now!!! Quote Link to comment Share on other sites More sharing options...
w41k3r Posted March 21, 2010 Share Posted March 21, 2010 sweet did you take pics ill prob need the info for when i do mie lol Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 21, 2010 Author Share Posted March 21, 2010 Yeah took a few pics! Was a tough task as in the past ive just cut the wires and put connectors on but I decided to splice the wires this time. Much stronger job takes double the time and its hard to get into the wires but made it in the end! Just need a support cable now to load the map on! If anyone has one to sell?? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted March 21, 2010 Share Posted March 21, 2010 (edited) the best one to get is a usb one from gifftech . the old serial bus ones dont work with alot of modern laptops. http://www.giff-tech.co.uk/ Edited March 21, 2010 by dr_jekyll (see edit history) Quote Link to comment Share on other sites More sharing options...
