Guest dlfredsupraman Posted March 13, 2010 Share Posted March 13, 2010 Before I get started I just want to say THANK YOU to the many people who have posted help and input for others. I just purchased my 1st Supra this week and I am thrilled to have something to go completely overboard on. I have reached my 47 years the hard way leaving behind a trail of broken bones, torn ligaments and nerve damage. I will miss motorcycles but plan on enjoying my Supra on the twisty roads of the North Georgia mountains. So anyway Thanks..great stuff. I just bought a 1986 Supra HB 5 speed about 100 miles from the house. The seller says that the following work has been done after the car owner brings it to him apart. Seems like a honest guy running a small repair shop, he tells me he had to purchase a download manual to help him assemble the car since he wasn't familiar with the car. This is what he did; Head Gasket replaced, cylinder head received a valve job,head resurfaced, brake master cylinder, plugs and wires. The car has sat for a couple years then sat again for 6 months after the repair. Starts up easy and does a cold start high idle of about 2300 and only drops to about 1300 rpm at warm idle. Wack the throttle and the idle will drop to about 1000 rpm and then very slowly climbs back up. Taking off from a start it doesn't seem to pull very hard, while accelerating if you roll back off the gas a little it seems to clean out a little and pull smoother. If you stay in it at about 4800 rpm it starts to pull a little harder and more smoothly. It doesn't smoke or knock at all. I included some pictures from under the hood, please feel free to ridicule and abuse but in return offer a fix for me. The distributor seems a little jacked to one side of the adjustment range. I am thinking that I hear a vacuum leak and although it looked like it was sealing OK the duct tape intake repair may be some of the problem. I appreciate any thoughts or suggestions. I can't figure out exactly where the parts that were left hanging go. There is a green one wire plug hanging there that I don't know if it should be hooked up. The code it's spitting out is 52, have not tested the Knock Sensor yet. The cruise doesn't work and the fuse is good. Thanks for your help. Dave Quote Link to comment Share on other sites More sharing options...
JustGav Posted March 13, 2010 Share Posted March 13, 2010 Welcome, although I do suspect you may wish to look at a mk3 supra site. That said we are a friendly bunch and not adverse to chatting about other cars Quote Link to comment Share on other sites More sharing options...
Guest dlfredsupraman Posted March 13, 2010 Share Posted March 13, 2010 Well, I will no doubt own a MKIV sometime in the future so I am glad to be able to come on board and learn from the pros. But in the meantime I apologize and will keep my comments and posts to a minimum. Although you are a "friendly chatty bunch" Thanks Quote Link to comment Share on other sites More sharing options...
JustGav Posted March 13, 2010 Share Posted March 13, 2010 Well, I will no doubt own a MKIV sometime in the future so I am glad to be able to come on board and learn from the pros. But in the meantime I apologize and will keep my comments and posts to a minimum. Although you are a "friendly chatty bunch" Thanks Oh not at all, feel free to hang around and post... There are lots of knowledgeable people here,so no need to be shy Quote Link to comment Share on other sites More sharing options...
Terminator Posted March 13, 2010 Share Posted March 13, 2010 (edited) Hi and welcome, there are many bikers and ex-bikers here as well as many who have owned MKIII Supras. So you are amongst friends. Edited March 13, 2010 by Terminator (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest dlfredsupraman Posted March 13, 2010 Share Posted March 13, 2010 Great. I appreciate it. I am not surprised to run into friends from my bike family. Quote Link to comment Share on other sites More sharing options...
