Will it ever end - smoked clutch
jevansio
  • Replies 56
Posted Images
I'm thinking of doing a full fluid change on the clutch/gearbox/diff after this little escapade, can anyone confirm to do the 3 that I don't need to drop anything major out the way (ie it's just a case of opening the drain/fill points, draining, then filling back up)?
yep thats it mate, easy job...
tip for you - first open the filling points up.. then realese the oil.
i have seen it before were oil has been released and the filling point wont budge lol
Cheers bud, was going to ring you tomorrow to say I won't be needing yoour services (well for now) :D
Cheers guys,
Changed my plugs today, put a fresh set of Iridium Grade 9's in, boy what a difference, and it's not in my head, it has actually made my peak boost change, seems a lot stronger under high load in the upper gears (where it felt lacking yesterday)
