Davey001 Posted April 22, 2010 Author Share Posted April 22, 2010 Honestly ask anything iam just greatfull of your help and advice! Yes i have the ignition on and the unit shows green light on active and yellow light on the usb bit to show connection!! Quote Link to comment Share on other sites More sharing options...
Steve Posted April 22, 2010 Share Posted April 22, 2010 Will have a think. Quote Link to comment Share on other sites More sharing options...
Davey001 Posted April 22, 2010 Author Share Posted April 22, 2010 Ok mate, thanks tho and if you come up with anything just let me know! Like i said it shows online on the support tool but wont let me export data to it or update the unit! Quote Link to comment Share on other sites More sharing options...
Homer Posted April 22, 2010 Share Posted April 22, 2010 I found a archive of the mohdparts site, in case it helps anyone... http://web.archive.org/web/20080118014046/www.mohdparts.com/emanage/index.html Quote Link to comment Share on other sites More sharing options...
Homer Posted April 22, 2010 Share Posted April 22, 2010 BTW, is the screen showing "Online" in the taskbar at the bottom right? Quote Link to comment Share on other sites More sharing options...
Davey001 Posted April 22, 2010 Author Share Posted April 22, 2010 yeah mate! Quote Link to comment Share on other sites More sharing options...
Homer Posted April 22, 2010 Share Posted April 22, 2010 Okay, that's good then Have you downloaded the communication program and run that? Quote Link to comment Share on other sites More sharing options...
Davey001 Posted April 22, 2010 Author Share Posted April 22, 2010 Okay, that's good then Have you downloaded the communication program and run that? Nope, Didnt relise there was one!! Quote Link to comment Share on other sites More sharing options...
Homer Posted April 22, 2010 Share Posted April 22, 2010 I've got a copy of the EMB setup instrcutions in front of me (available from the mohdparts site) and also displayed here: http://web.archive.org/web/20080117043655/www.mohdparts.com/emanage/manuals/emanage_software_manual/index.html (Page 11 onwards) This will remove any map currently installed on the EMB, but I assume that's not an issue... Here's the start. Download the communication program (Main unit update) 1) Always disconnection the 12 pin connector on the main unit 2) Check and make sure that the status bar is displaying "ONLINE". If it does not show "ONLINE" check your com port settings 3) The program will automatically detect a new unit with an old system program. When the update window shows on the screen, click "OK" to start downloading the update etc... I'd recommend running through this exactly as it says and see if you can get the map screen loaded Quote Link to comment Share on other sites More sharing options...
Davey001 Posted April 22, 2010 Author Share Posted April 22, 2010 If i remove the 12 pin connector will it still have power to the unit to work or does it not need power? Quote Link to comment Share on other sites More sharing options...
Homer Posted April 22, 2010 Share Posted April 22, 2010 No idea mate, but that's what the instructions say! Power might be supplied by the USB cable, I'm not entirely sure... It's only flashing the unit so might not need full power supply. Edit: BTW, can you try this first... Turn the ignition on Go to 'main unit setting information' under 'setting' Do you get a window displayed? Quote Link to comment Share on other sites More sharing options...
Davey001 Posted April 22, 2010 Author Share Posted April 22, 2010 Ok i'll have a try now! Quote Link to comment Share on other sites More sharing options...
Homer Posted April 22, 2010 Share Posted April 22, 2010 Before you do, see the edit above! Quote Link to comment Share on other sites More sharing options...
Davey001 Posted April 22, 2010 Author Share Posted April 22, 2010 yeah i do! Quote Link to comment Share on other sites More sharing options...
Davey001 Posted April 22, 2010 Author Share Posted April 22, 2010 The main unit update doesnt work, its counts on the timer but nothing if being downloaded! got upto 12mins and nothing had gone onto it. Quote Link to comment Share on other sites More sharing options...
Homer Posted April 22, 2010 Share Posted April 22, 2010 So, can you actually view the current map on the ECU? (might need to select 'real time' option) If you can do that I cannot see how this can be a communications issue. Is it correct that you have a map file on your laptop you're trying to load onto the EMB? If so, try turning off real time update, open the map from your laptop then export this to the ECU Quote Link to comment Share on other sites More sharing options...
Davey001 Posted April 22, 2010 Author Share Posted April 22, 2010 I cannot veiw any current data on the emb, i do have a map which iam trying to export to the emb but when i open the map onto the emb and try to export it wont let me, thats when the communication error comes in Quote Link to comment Share on other sites More sharing options...
Homer Posted April 22, 2010 Share Posted April 22, 2010 I cannot veiw any current data on the emb, i do have a map which iam trying to export to the emb but when i open the map onto the emb and try to export it wont let me, thats when the communication error comes in Sorry mate, I've not touched an EMB for 4 years so I'm running out of ideas. If as above you can view the 'main unit information' it is pulling data from the ECU. Can you view any other settings from the ECU or open the fuel tables? From what you've said it seems that the import and export option are not working. I'll PM Ian C and ask him to take a look at the thread but doubt he'll be online now. Quote Link to comment Share on other sites More sharing options...
Davey001 Posted April 22, 2010 Author Share Posted April 22, 2010 Cant veiw anything from the ecu, I can change settings in the settings bar, like the main unit setting, i an tick boxes and what ever else but can update them back onto the unit. Yeah that would be great if you could do that! Running out of ideas myself, looking like a new one! Quote Link to comment Share on other sites More sharing options...
Homer Posted April 22, 2010 Share Posted April 22, 2010 Cant veiw anything from the ecu, I can change settings in the settings bar, like the main unit setting, i an tick boxes and what ever else but can update them back onto the unit. Yeah that would be great if you could do that! Running out of ideas myself, looking like a new one! Okay, just to be clear on what I'd asked earlier: Do a fresh connection to the EMB. Turn on real time connection. Do not open your laptop saved map file. Turn the ignition on. Go to 'main unit setting information' under 'setting'. Check that a window opens and displays the unit settings with 7-4-0 in the top left. If that happens it confirms you have a connection to the ECU. If you have that, try viewing the other tables and options and see if it pulls any data, or gives a communication error. PS: Do you have a wireless network connection on your laptop? I could setup a remote session from here and take a look directly... Quote Link to comment Share on other sites More sharing options...
Davey001 Posted April 22, 2010 Author Share Posted April 22, 2010 Nothing shown in main unit settings, all blank! Quote Link to comment Share on other sites More sharing options...
Homer Posted April 22, 2010 Share Posted April 22, 2010 Right, well it's a connection problem then! Last shot at this - have you tried downloading the driver from the mohd site? Quote Link to comment Share on other sites More sharing options...
Davey001 Posted April 22, 2010 Author Share Posted April 22, 2010 So there is no connection at all! When i just have the usb cable plugged into my laptop and disconected from the emb it still shows online on the software so this means its never been online its just showing the lead connected! Quote Link to comment Share on other sites More sharing options...
Davey001 Posted April 22, 2010 Author Share Posted April 22, 2010 Really big thanks for all you help on this, I hate wasting peoples time! Havent tried that driver! Quote Link to comment Share on other sites More sharing options...
Homer Posted April 22, 2010 Share Posted April 22, 2010 So there is no connection at all! When i just have the usb cable plugged into my laptop and disconected from the emb it still shows online on the software so this means its never been online its just showing the lead connected! Yeah, then it's being misreported and indicates either a driver issue or incorrect USB cable (as you know they are specific to the Greddy (and some mobile phone communication kits)) Quote Link to comment Share on other sites More sharing options...
