GazzaGSi Posted March 22, 2010 Share Posted March 22, 2010 You'll be with that mate. Sounds like you did good with it whining before the conversion! Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted March 22, 2010 Share Posted March 22, 2010 yea it should be ok fingers crossed. shame you dont have yours , lookd a real beast Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 24, 2010 Author Share Posted March 24, 2010 N/A T Build. Xs T4 Turbo Xs T4 Manifold Xs Downpipe with V band clamp Xs 3" Intercooler (Brackets Need to be made) Universal Intercooler pipe kit : (This Kit Includes: (2) 90 degrees Mandrel Bent Pipes, (2) 75 degrees Mandrel Bent Pipes, (2) 45 degrees Mandrel Bent Pipes, (2) Straight Pipes, (2) 90 degrees Elbow Couplers, (6) Straight Couplers, and (16) Clamps.) 2x 3" Silicone Elbow couplers 1x 3" - 2" Silicone Elbow Reducing Coupler Universal Xs 50mm Wastegate + Fittings Screamer Pipe Oil Feed Line 6an braided with straight couplers, T Fitting to fit union bolt for feed and 6an 90 degree for turbo. Oil Return Line 10an braided with 45degree couplers, 10an 90 degree bend for sump and 10an coupler for turbo. Flanges for oil feed+Return x3 Gaskets for Manifold, T4 turbo, Wastegate, Downpipe. I bought a sheet and cut my own. Dissy Cap Toyota 4runner 3.0l 2959cc V6/3VZE Part No. QHXD408 5m of 3mm Vacuum Hose 3x 3mm Barbed T's 2x 02 sensors to replace existing Cone Airfilter BOV + Adapter for fitting Heat Wrap + Stainless Steel Tie wraps Greddy Emanage Blue or similar with Boost map sensor Wideband Lc1 kit or similar Boost + Oil Pressure + Temp Gauges Turbo Blanket Hope Ive put everything on but if Ive missed anything let me know and I will update it! Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted March 24, 2010 Share Posted March 24, 2010 just while its in my mind , what clutch have you got ? Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 24, 2010 Author Share Posted March 24, 2010 just while its in my mind , what clutch have you got ? Stock at the mo! Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted March 24, 2010 Share Posted March 24, 2010 looking good dave. Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 24, 2010 Author Share Posted March 24, 2010 looking good dave. Cheers mate, off work till wed next week now so its time to get this finished and get it fired up! Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted March 24, 2010 Share Posted March 24, 2010 will it be at japfest , id love a nose around it Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted March 24, 2010 Share Posted March 24, 2010 Cheers mate, off work till wed next week now so its time to get this finished and get it fired up! good luck buddy, fingers crossed for you. im being slowly pushed to the single on a tt conversion, but wait to see your results first Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 24, 2010 Author Share Posted March 24, 2010 will it be at japfest , id love a nose around it Was that for me? When is it? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted March 24, 2010 Share Posted March 24, 2010 erm may i think , have a look at the link in the national events forum Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 24, 2010 Author Share Posted March 24, 2010 Will do now!! Quote Link to comment Share on other sites More sharing options...
w41k3r Posted March 24, 2010 Share Posted March 24, 2010 very good list mate will help loads Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 24, 2010 Author Share Posted March 24, 2010 very good list mate will help loads No probs mate hope it helps! Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 24, 2010 Author Share Posted March 24, 2010 erm may i think , have a look at the link in the national events forum Just had a look, Its possible I could go but would have to wait and see as I have to work alot of weekends to keep the buisness running! Looks good tho! Quote Link to comment Share on other sites More sharing options...
Homer Posted March 24, 2010 Share Posted March 24, 2010 Davey, good to see you have replaced the oil feed and supply lines with your own Just a few things to make sure you are on track for a more trouble free build: - Make sure you have the manifold faces machined, they WILL be warped! The two key ones are the face to the block and the T4 face to the turbo. It doesn't cost much to do and will save you a lot of problems in the mid-term. - Make sure that you do not use the XS oil drain gaskets, make your own or use seomthing from the likes of BL, they are pence to buy - I recommend using the stock manifold gasket rather than a sheet one. It's a very high quality item and will last far longer. - Ensure that the intake track to the cast manifold is wrapped very well, heat soak on the NA-T setup is extreme and a power killer. It can be helped by wrapping the manifold, but that may not make it last past a year or two. - I highly recommend you do not use the XS power v-band clamps, they are extremely weak and will fold up with the slightest of torque. Again, good quality items are only a few quid. - Check the v-band flange on the DP is tapered, a lot I've seen are not and it will not allow the v-band to clamp on it properly Keep us posted, pics always welcome Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 24, 2010 Author Share Posted March 24, 2010 Davey, good to see you have replaced the oil feed and supply lines with your own Just a few things to make sure you are on track for a more trouble free build: - Make sure you have the manifold faces machined, they WILL be warped! The two key ones are the face to the block and the T4 face to the turbo. It doesn't cost much to do and will save you a lot of problems in the mid-term. - Make sure that you do not use the XS oil drain gaskets, make your own or use seomthing from the likes of BL, they are pence to buy - I recommend using the stock manifold gasket rather than a sheet one. It's a very high quality item and will last far longer. - Ensure that the intake track to the cast manifold is wrapped very well, heat soak on the NA-T setup is extreme and a power killer. It can be helped by wrapping the manifold, but that may not make it last past a year or two. - I highly recommend you do not use the XS power v-band clamps, they are extremely weak and will fold up with the slightest of torque. Again, good quality items are only a few quid. - Check the v-band flange on the DP is tapered, a lot I've seen are not and it will not allow the v-band to clamp on it properly Keep us posted, pics always welcome Ok mate, thanks for the advice! I have used replacement parts all the way through as I didnt buy a complete kit, I bought everything seperate. I thought it was pointless buying a kit and not using most of the parts! Will keep you updated with how I get on! Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 28, 2010 Author Share Posted March 28, 2010 Hey guys started fitting everything to a finish now just some pics to update what ive been upto! Got everything ready to bolt on tomorow,just need to pick some new oil up! Anyone recommend any brand of oil and thickness? Do i need more oil in now with having a turbo fitted as there are more oil lines, or is it just the same amount? Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 28, 2010 Author Share Posted March 28, 2010 Fitted this new carbon wing yesterday, got rid of that veilside one! Also got carbon bonnet to fit once everything is finished! Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted March 28, 2010 Share Posted March 28, 2010 got some rear wing mate, nice Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 28, 2010 Author Share Posted March 28, 2010 got some rear wing mate, nice Think it looks better than the veilside? I think so! Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted March 28, 2010 Share Posted March 28, 2010 yeah mate i think it looks ok, better than the veilside Quote Link to comment Share on other sites More sharing options...
Davey001 Posted March 28, 2010 Author Share Posted March 28, 2010 How's your sup going? You guna start anything soon? Quote Link to comment Share on other sites More sharing options...
JamieP Posted March 28, 2010 Share Posted March 28, 2010 That exhaust looks like its sticking out about a foot? get one the other side and thats king kongs flashy wheel barrow you got there:d;) Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted March 28, 2010 Share Posted March 28, 2010 yeah i got it in the project section, all the interior is away still being retrimmed cant wait its going to look awesome. carpets have been made now and the trimmer is coming down to fit in the week. engine wise? im going to prob start end of the year, prob tt conversion Quote Link to comment Share on other sites More sharing options...
