MkIII supra boost limit
hodge
I'm doing some work on a mkIII at the weekend including fitting a boost controller. Does anyone know the safe boost limit for a CT26 turbo. I would have thought it would be around the 1.2 bar mark.
Anyone know for definate.
Thanks
John
Fuel cut varies on the mk3, people have had it as low as 9psi and over 14 psi. The generally accepted limit is about 14 psi normally.
A FCD can help with this but you run the danger of fuel cut not kicking in when you actually do need it.
Shimming the wastegate is a common mod that can easily knock you off the top of the stock gauge so ~10 psi+
With lexus+550s you can go way past that to high teens or low 20s but that's down to other factors such as afr setup as well
Has it got a standard exhaust with cats? Losing them will gain you a few PSI, obviously make clear to the owner the more they boost the more likely they are to need a head gasket!
Oh and 14.5 psi = 1 bar
