Rear Top Arm Replacement - Difficult?
dandan
Has anyone replaced their rear top arms and done it using a jack and axle stands as opposed to using a ramp/lift?
I've only had a quick look and the fixing points to the subframe look a little difficult to get to. Does it get a bit more obvious when the car is in the air? Please tell me I don't need to do anything hefty like dropping the subframe to do it?
Any pointers will be greatly appreciated?
Cheers
Dan
The hardest part i found when changing mine was undoing the 2 bolts that go through the bushes, they were seriously tight !!
Mine was done on a ramp so not sure how easy this would be on the floor on axle stands.
You dont need to drop the subframe but think you undo them from under the car, cant remember now but i know it was a squeeze to get at the nuts on the ends of the 2 bolts
Not sure if the pic is any use but heres 1 i took
http://www.mkivsupra.net/vbb/showthread.php?t=193133
The above thread is when I was doing this sort of thing if you want a look. The bolt nearest the front of the car was put in the wrong way around, which was confirmed after looking at EPC diagrams, so I had to take the subframe off. You shouldn't have this problem though.
That nut is annoying to get to and you'll probably scrape your wrist a bit but you should manage.
............. i know it was a squeeze to get at the nuts on the ends of the 2 bolts
That's what is worrying me - after a quick look from under the arch the nuts/bolts look damn near impossible to get at.
If mine are as tight as your's (most likely :) ) then there will be no chance of pissing around with an open ended spanner - I'll need a decent socket or at least a ring spanner on there......and the same to do them back up again.
Cool, thanks for the link. Looks like you had some fun and games doing that little lot. I see what you mean about your bolts being put in the wrong way.....weird.
both of my rears need changing. slight hi jack but wheres the best/cheapest place to get them from?
I'd try Paul Whiffin and Steve Manley.
one of the bolts looks like you cant get a spanner onto the other side as the subframe is in the way.. dont worry toyota have already thought of this and made the nut with an elongated side that locks by hitting the subframe alowing you to remove the bolt.. its easy but they are tight..
IF you arent using a balljoint splitter and are using a lump hammer to remove the ball joint by shocking the cast hub, make sure you dont undo the bolts, remove the ball joint first as the extra movement of undoiing the bolts or removing them will make shocking the ball joint out next to impossible...
Try it its easy
Shouldn't be too bad as the bushes come in 2 pieces, some good lube and a press and should fly in. famous last words.
Polybushes are fitted by hand, once both sides are in you can push in the insert again by hand, no tools nessessary.. just lube up the bushes and the insert or they will squeak like a bugger..
you will need a socket on a bar (i used my ratchet with a long bar over the handle as its easier to get the socket and bolts to line up to get leverage.. I broke the ratchet though lol) They are bloody tight. Just apply pressure dont yank at it and they will give.. WD40 helps to..
