Guest KernalRob Posted March 10, 2010 Share Posted March 10, 2010 I have a 95 N/A 5 Speed (W58 Gearbox) When i start the car i get a whining noise from the clutch / gearbox which sounds like a bearing spinning (loudly) when i push the clutch pedal down the noise stops. I continue to get this noise as i am accelerating through the gears with the whining increasing as my engine speed increases. When i press the clutch down and rev the engine as im driving the noise stops so i know its not the engine. I've replaced my gearbox oil which did nothing and all the gears seem to select as normal. Anybody got any ideas what it could be! Link to comment Share on other sites More sharing options...
Neil-NA Posted March 10, 2010 Share Posted March 10, 2010 Sounds same as mine which i believe is the clutch release bearing. Link to comment Share on other sites More sharing options...
AlexM Posted March 10, 2010 Share Posted March 10, 2010 Probably the thrust bearing (though I changed mine, and still have the noise). Link to comment Share on other sites More sharing options...
Racman Posted March 10, 2010 Share Posted March 10, 2010 Yep new clutch me thinks mate sorry Link to comment Share on other sites More sharing options...
Guest KernalRob Posted March 10, 2010 Share Posted March 10, 2010 Yep thought i might be the thrust bearing. Read some stories on here though of possibly Input shaft bearing so hoped it wont be that. Link to comment Share on other sites More sharing options...
dr_jekyll Posted March 10, 2010 Share Posted March 10, 2010 mine has allways been verry loud , iv had three clutches , 3 thrust barings and three pilot barings. it has to be the box Link to comment Share on other sites More sharing options...
Guest KernalRob Posted March 11, 2010 Share Posted March 11, 2010 Is there anyway you can check if it is the thrust bearing without replacing it. Link to comment Share on other sites More sharing options...
