'Run-away' Toyota Prius's
SupraStar 3000
There's several things you can do as a driver if you're thinking straight, have sufficient presence of mind and a non-blinkered approach to what a car's controls do.
Unfortunately many drivers these days fail most/all of these criteria. I do accept it could be alarming if your brakes fail.
If I were in that situation, I'd like to think I'd have sufficient presence of mind to use the gears to slow down if possible, then on a straight bit of road key off the engine and immediately set the ignition back to the 2-position, to disengage the steering lock. The braking system should have a small number of "pumps" in it before you'd lose servo assistance: use those pumps wisely!
That should work on something like a supra, but I don't know if it would apply to the Prius' complex electronics.
All good comments, have any of you actually been in a Prius? It's keyless, the key is in your pocket (on the latest model), so you can't 'switch off the engine', I have no idea what would happen if you pressed the 'START' button whilst driving - probably nothing. Also, there's no handbrake, only a footbrake (next to the 'foot' brake :blink: ), and a P button (which again, probably does nothing when driving). Plus, they're auto and the gearbox is electric, you have to hold it over N for a few seconds before it disengages D.
Basically it's all very confusing and not straight forward to slow down if the brakes fail or throttle sticks or whatever it is with Toyotas today.
That can't be 100% true, how on earth would you turn off the car when parking up? Put the handbrake on and walk away? lol
I'm not sure how it works, but it's a very clever vehicle so I guessed it wouldn't let you turn the 'engine' (obviously the actual engine is off when you stop anyway) off when driving, only when you've stopped and put it into park or put the brakes on.
I would guess those Priuses are switching to electric engines once you drive slowly, so when you stop, it basically is not running at all. Once you go out and press "close" button" it switch itself off.
Anyway, I like to stick to older type cars where electronics does not spoil my driving experience :)
what was wrong with a trhrottle cable connected to the peddle? i think cars should all revert back to early 90s technolighy with lastes safty standars.
AFAIK fly by wire throttle and brakes aren't allowed on the roads yet, and the Prius does have a cable. I think it was a case of the pedal mechanism sticking because of a missing metal plate on the pedal arm?
Not entirely true, FBW throttles have been around for years. The Gen II Prius, as far as I know, has a FBW throttle, gear selector and push button start, which shortens the choices you have in an a run away situation. Toyota are claiming a worn mechanism in the pedal as the cause of this problem, even thought they are recalling Japanese only Prius's for software problems relating to braking and throttles...the plot thickens.
