Fuel Pump
Geezabloke
Finally got round to fitting the new UK fuel pump (sourced via CJ, Thanks mate).
After reading some great write ups on how to do it step by step, the whole job took an hour. That included searching for tools etc.
I removed the filler cap prior to removing the hoses etc as suggested (to release the pressure in the lines) and had the tiniest amounts of petrol spill out whilst working.
Car started again on the first turn.
Thanks guys for the write ups.
Dave :rtfm:
  • 1 month later...
Scott try this.
If you using an OEM pump you wont need to do the soldering of the terminals.
This BTW was originally by Matt H
1. open boot
2. remove boot cover and spare wheel
3. remove 6 bolts from around the fuel tank access cover, (directly under the spare wheel)
4. remove all pipework and wiring harness. keep a cloth handy as you're about to be spayed with fuel! (3 pipes, two are only on with clips, one banjo bolt, don't lose the washers,!)
5. remove large jubilee clip from sealing ring, then remove the sealing ring (this is easiest done with a massive pair of pliers, but can be done by tapping the ring with a large flat screwdriver and a hammer anticlockwise. Make sure you don't tap the screwdriver through the plastic ring.
6. carefully lift out fuel pump cage assembly
7. remove old fuel pump, (unclips at the bottom, and has a hose and wiring connector at the top.
8. solder or crimp the new pump wiring loom making sure it's the correct length, (make sure that the connection is well insulated, and not with insulation tape as this will disintigrate in fuel)
9. re-fit new pump assembly in the same manor that the old one came off, (don't forget the little retaining clip that holds the filter bag to the base of the pump)
10. carefully re-insert pump cage assembly
11. refit sealing ring, (this is the hardest part, it's a bugger to get it on, and I'd guess this is the bit that will take you the longest. We've found that if you spray lubricant on the thread, then start it by hand, and resort to tapping with a hammer screwdriver again, (clockwise obviously), if the ring pops out of the thread slightly, tap it around a little bit more, then tap down the edge thats sticking up)
12. refit big jubilee clip
13. re-fit hoses and wiring. (When you re-fit the main fuel line banjo bolt, you need to hold the whole assembly as spanner tightning will move it all out of line. Also, remember to put the small washers either side of the banjo bolt)
14. start car and check for fuel leaks. (car may stall at first as you've now lost fuel pressure and it'll take a little time to get back there)
15. if all is well, refit access plate, spare wheel and boot gubbing.
16. clean up, have a cup of tea and feel good about saving yourself money and sucessfully doing a worthy modification all by yourself...
Dave :devil:
